Ipad sound but no video when connected to TV
This is a discussion on Ipad sound but no video when connected to TV within the iPad Help forums, part of the Apple iPad Discussions category; Today I purchased the Apple Component AV Cable MB 128ZA/B from the Apple store in Bath, Somerset. I connected the 3 video and 2 sound ...
Results 1 to 6 of 6
    7206
    Jun 2010
    Templecombe,Somerset,England
    Today I purchased the Apple Component AV Cable MB 128ZA/B from the Apple store in Bath, Somerset. I connected the 3 video and 2 sound leads to my Philips 42" TV and the docking cable to the Ipad. I then tried to watch a video the sound was perfect but no video appeared on my TV. I did the same with YouTube with the same results. I also have a Panosonic 26'" TV which is 6 years old, made the same connections and had the same results!!!.
    Have I got the wrong cable, the guy in the Apple store seemed unsure if the Ipad would work with a TV?
    6507
    Jun 2010
    Seattle
    459
    Are you plugging the red, green, and blue video plugs into the red, green and blue plugs at the tv? Those colours need to match up. You can't plug it into a red, white or yellow plug.
    Also, did you select the correct input source on your tv? The on screen tv choices are typically, TV, AV1, AV2, HDMI, etc. Make sure you pick the one that matches what you plugged the cables into.
    And absolutely, the iPad plays movies, photos and videos to the tv. I use a composite AV cable with mine. Your component cable should work too.
    iPAddict - 16Gig WiFi with Zagg InvisibleSHIELD Front - clear Hard Candy Sleek case - Built NY sleeve - Freedom Pro folding Bluetooth keyboard - Microsoft Bluetooth 6000 keyboard - Boxwave stylus - DIY LEGO stand, 3feet stand & DIY fold-flat stand
    7206
    Jun 2010
    I have double checked that the plugs are connected into the correct sockets and that the correct input is selected, still sound only!. A message comes up on the TV screen No Video Input.
    6507
    Jun 2010
    Seattle
    459
    Perhaps a faulty cable?
    What were you trying to watch? Did you try other movies or do a slideshow of your photos?
    There is no setting needed on the iPad either. Once connected and the tv input is selected, sound and video should work.
    I'd say if even the photos aren't displaying, try exchanging the cable set for another one.
    7206
    Jun 2010
    Just been down to the Apple store in Exeter, after trying several sets of cables we found one that worked. The problem with the Apple Component AV cable is that the connection to the plugs are weak, not much force required to break them. Anyway problem solved, thanks for your help guys.
    7075
    Jun 2010
    ohio
    13
    my Apple AV cables do not work for iTunes movies, flixter app
    it does work for netflix, YouTube, wired magazine and cNet.
    I sent a question. to apple support, will post answer
  1. No sound in headphones
    By ncbrew in forum iPad General Discussions
    Last Post: 03-18-2012, 11:19 PM
  2. Replies: 14
    Last Post: 06-16-2010, 01:27 AM
  3. sound recordings where to find
    By littlebuddha in forum iPad Help
    Last Post: 06-15-2010, 02:05 AM
  4. ipad paired but not connected????
    By Katilea in forum iPad General Discussions
    Last Post: 06-14-2010, 02:04 PM
connecting ipad to tv sound but no picture
gigaware no video output ipad to tv geek squad
i pas to tv audio but no video
ipad av cord no video
ipad connected to tv no picture
ipad connected to tv sound but no picture
ipad to tv no video
ipad video to apple tv audio only
no picture when i connect ipad to tv
no video from ipad to tv
no video on tv from ipad
plugged in ipad to tv nomvideo only audio
