Horizontal please help me!
This is a discussion on Horizontal please help me! within the iPad Help forums, part of the Apple iPad Discussions category; hey I have an apple iPad (durr) and normally if you sit it upright the screen will sit vertically and if you lay it on ...
Results 1 to 6 of 6
    158252
    Jan 2012
    hey
    I have an apple iPad (durr) and normally if you sit it upright the screen will sit vertically and if you lay it on the side to play apps and such it will rotate to horizontal. but now it's stuck on horizontal! I've tried everything, including turning off my iPad. I can't find anything in the settings and I'm on the verge of throwing my iPad in frustration! PLEASE HELP!
  2. #2
    13576
    218 times
    Aug 2010
    Western NY state (USA)
    5,118
    Could you have accidentally moved the side switch and thereby cause it to lock? Sometimes, it's a little sensitive and a touch will move it - you won't even notice it.
    If that's not it, holler back and we'll see what else it could be.
    Black 64GB WiFi/4G iPad3 (iOS 5.1.1; jailbroken w/Absinthe 2.0) & black 64GB iPhone 4S (iOS 5.0.1; jailbroken w/Absinthe 1.0)
  3. #3
    158252
    Jan 2012
    what's a side switch and where is it located?
  4. #4
    13576
    218 times
    Aug 2010
    5,118
    As you hold your iPad so that the Home bottom is on the bottom (in portrait mode), the switch is on the upper right side. However you find the switch, move it to the opposite side and see if that solves your issue.
  5. #5
    158252
    Jan 2012
    nope, nothing is happening
  6. #6
    iPF Elite
    176 times
    Dayton, WA
    9,229
Sponsors
  1. New IPad won't rotate to Horizontal View
    By haziepops in forum iPad Help
    Last Post: 12-25-2011, 08:27 AM
  2. Horizontal Apps
    By larla in forum iPad General Discussions
    Last Post: 06-25-2011, 11:53 AM
  3. Horizontal Line in Office2HD
    By siteplan in forum iPad Apps
    Last Post: 05-31-2011, 04:23 PM
  4. Screen not shifting from vertical to horizontal
    By corner crawler in forum iPad Help
    Last Post: 01-25-2011, 12:28 PM
  5. Keynote only HORIZONTAL view? Are you kidding me?
    By shodka8 in forum iWork Forum
    Last Post: 12-30-2010, 02:36 AM
apple ipad screen turn from vertical to hprizontal
how do i ger my ipad to go horizontal
how do i get my ipad to go horizontal?
i cant view horizontally on y ipad
ipad horizontal view
ipad is stuck in horizontal
ipad screen horizontal
ipad stck on vertical
ipad stuck horizontal
ipad stuck in horizontal
ipad stuck on horizontal
ipad stuck vertical
ipad stucked in horizontal
ipad vertical to horizontal
ipad wouldnt turn from horizontal to vertical
new ipad will not move horizontally
please rotate my ipad horizontally
vertical and horizontal view in ipad
verticle and horizontal on ipad?
why won't ipad screen rotate horizontall
