Problem about Mail settings
This is a discussion on Problem about Mail settings within the iPad Help forums, part of the Apple iPad Discussions category; Sometimes when I access my mail, either through me.com, or through wanadoo.fr, and also through iCloud, I get a message saying that there is something ...
Results 1 to 7 of 7
    157699
    Jan 2012
    France
    31
    Sometimes when I access my mail, either through me.com, or through wanadoo.fr, and also through iCloud, I get a message saying that there is something wrong with my settings and the system cannot handle either displaying mail on the screen, or sending it from my iPad. The message preview is displayed on the left side of the screen in landscape view, and when sending I can get as far as hitting the Send button.
    In response to the instruction to review settings, I go to Settings and click on Mail. Then, without doing anything else at all, I click on DONE, whereupon the problem disappears, the incoming mail is displayed, and the outgoing mail is sent.
    What is going on and should I do something about it?
    577 times
    Dayton, WA
    13,177
    Could just be a glitch, could be a problem with specific emails. Keep an eye on it and see if you notice it popping up in conjunctions with specific emails senders.
    If you have not done so, give these common fixes a try and see if they help.
    You can also try deleting and re-adding the accounts and see if that helps.
    157699
    Jan 2012
    France
    31
    Quote Originally Posted by twerppoet
    I
    I have tried your suggestions, but the "feature" still occurs. If I manage to fix i I will post my findings.
    Thanks for your help
    577 times
    Dayton, WA
    13,177
    Ok. Sorry not to be of more help.
    157699
    Jan 2012
    France
    31
    Quote Originally Posted by Moray
    I
    Hi! I have looked at the mail settings again, and I am still getting the problem. It seems always to say that it cannot find the me.com account, but as I said before, all I have to do is go to the Mail account page and hit "Done" without doing anything else and all is well. Also, although it says it can't find the account, it first sends my message using that account and THEN tells me it can't find it. My other accounts are wanadoo.fr and iCloud, and the default is "mobile.me". I wonder if it is to do with the discontinuing if mobile.me. If so, perhaps I should erase everything to do with the mobile.me and me.com and then start agin from zero. What do you think?
    Neville
    37823
    477 times
    Cranbrook, Kent, UK
    15,230
    Neville
    My main email account is mac.com (me.com) and I haven't had any issues at all with it so I suspect the issue is somewhere else.
    157699
    Jan 2012
    France
    31
    Quote Originally Posted by Gabriel1
    Thanks. Fortunately it is annoying but not incapacitating!
    Nm
  1. E-mail settings & contacts close
    By anna_e in forum iPad Help
    Last Post: 12-07-2011, 10:08 AM
  2. Outgoing mail settings.........
    By lordmarshall2011 in forum iPad 2 Forum
    Last Post: 10-22-2011, 03:03 AM
  3. stmp outgoing mail settings for unicom- china
    By hancor in forum iPad General Discussions
    Last Post: 09-15-2011, 01:51 AM
  4. Mail and Mail Settings will not open
    By gmhd404 in forum iPad Help
    Last Post: 07-12-2011, 05:30 AM
  5. Mail settings question
    By WTK in forum iPad General Discussions
    Last Post: 04-04-2011, 06:32 AM
can't email from wanadoo to comcast
cant find the mail settings ipad
ipad can't go to mail settings
ipad sending email from wrong account
my ipad sends mail from the wrong account
wanadoo email ipad
wanadoo email settings ipad
wanadoo email setup ipad
wanadoo ipad email settings
wanadoo.fr email settings
wanadoo.fr email settings iphone
wanadoo.fr mail problem
