Applications running in background often restarts when opened
This is a discussion on Applications running in background often restarts when opened within the iPad Help forums, part of the Apple iPad Discussions category; Hi guys, don't know if anybody has encountered this problem on iPad2 but I've found out that if the application is first closed and then ...
Results 1 to 10 of 11
    157277
    Jan 2012
    20
    Hi guys, don't know if anybody has encountered this problem on iPad2 but I've found out that if the application is first closed and then opened after some time running on background it gets restarted as if it is opened for the first time. I can see it especially with safari - if I reopen it after some time all tabs are reloaded even if I can see previous content rendered for a second or two - but then reloads. This is really frustrating . Similar issue I have with other application such skype (but this is maybe another problem) or iPF application - it starts reload and land on homepage even if I was in another thread before. It behaves as it starts from the scratch. Has anybody encountered such behavior ? Could it be anything with memory management, could it be avoided? Thx.
    iPad 2 32Wifi 5.0.1 JB
  2. #2
    48665
    160 times
    Brisbane, Australia
    9,545
    Yes this does happen, these applications aren't actually running in the background, they are just dormant. If you start another app and it needs more ram to run, the iPad will close these apps completely. Safari with certain sites open takes up a lot of ram. If you don't want this happening, closing apps and tabs on safari will limit it.
    iPad 2 64gb 3G
  3. #3
    157277
    Jan 2012
    20
    Thx for answer, leelai. I would say it happens quiet often, but at least it is not a problem of the device but the iOS5. Is there any way how to explicitly say "do not close this app whatever happens"? Maybe any cydia tweak or something like that? Or there is nothing we can do with it? Thx
  4. #4
    A.K
    A.K is offline
    118496
    2 times
    Oct 2011
    India
    53
    I guess u can't do anything about it. iOS doesnt support proper multitasking .only certain apps like music and yahoo messenger runs in back ground. The rest of the apps are freezed in the background.its also one of the main reason why iOS is super smooth without any lags.
    from my white I pad 3G/wifi 16 gb
  5. #5
    157277
    Jan 2012
    20
    It would be fine if they would freeze but their aren't :-( their lose their state as soon as a new app requests for more memory as available and iOS automatically turn off one or more applications running in background even it looks as it is still running in multitasking. It could save their state to flash disk or something like that and not turn them off completelly.
  6. #6
    48665
    160 times
    Brisbane, Australia
    9,545
    I don't feel there is anything that you can do here except limit what is still open in the multi task bar and Safari.
    How many apps do you have running? I will usually have about 8 open with Safari running with tabs for this forum and when I go back and forth to Safari each tab is how I left it. When was the last time you did a restart and or reset on your iPad? It is a good idea to do this occasionally, it's maintenance for your iPad.
    iPad 2 64gb 3G
  7. #7
    157277
    Jan 2012
    20
    Quote Originally Posted by leelai
    Usually up to 5 apps and few - 4 to 5 tabs in Safari. Sometimes it keeps its state and sometimes it restarts. It is very unpredictable. Seems there is really no real multitasking. iOS simply kills your backgrounded application if there is no free memory no mater you want it or not. It is very annoying for social applications such im+. There should be a setting where you may define apps that should never be switched off or at least their state should be persisted on disk. I noticed if I open such application I can see the last state for 2 seconds or so but then it get restarted in front of my eyes - does it mean it's only a screenshot of last state when it was minimized or what?
  8. #8
    48665
    160 times
    Brisbane, Australia
    9,545
    I guess screen shot is a good way of putting it, but it has lost its connection and refreshes. The apps I have running aren't high use ones. Some apps can be huge, especially gaming ones and some websites can be like this too. I have a link that will explain how it all works, have a look it's quite interesting.
    http://player.vimeo.com/video/34660348
    iPad 2 64gb 3G
  9. #9
    157277
    Jan 2012
    20
    Thanks for sharing the video. Now I understand how all this works. Is there any key which apps are rejected from memory first? From biggest to lowest? Obviously there are system processes which are not killed at all so there could be also some switch for other apps implemented. Because usually the memory gets filled up very quickly so demand for 1024MB is very reasonable. Maybe iPad 3 or 4 will introduce it :-)
  10. #10
    48665
    160 times
    Brisbane, Australia
    9,545
    Quote Originally Posted by misenko
    I don't know which are killed off first, maybe that guy in the link might know or it may just be random. The best outcome for iPad 3 and 4 would be more ram, apps are only going to get larger and as you are discovering what we have now is really not enough with what we want our iPads to do for us. The more we get the more we want!
    iPad 2 64gb 3G
Sponsors
  1. iPad 1 freezing after eight or more applications are opened
    By LESHMAN in forum New Member Introductions - Site Assistance
    Last Post: 01-26-2012, 06:12 AM
  2. ipad 2 restarts pc
    By dhigh in forum iPad Help
    Last Post: 12-27-2011, 12:02 AM
  3. Mxtube running in the background?
    By jarell162 in forum iPad Hacking
    Last Post: 08-02-2011, 12:01 AM
  4. app that allows scribbling on the screen while running in background?
    By Spielor in forum iPad General Discussions
    Last Post: 03-04-2011, 12:12 AM
  5. How to close apps running in the Background
    By Al Rogers in forum iPad General Discussions
    Last Post: 02-19-2011, 10:55 PM
apps working in background ipad 2
are there programs that run in the background on my ipad
how do i close running in the background on my ipad
how often do i have to close ipad background apps
how to close background apps on ipad
how to kill apps running in the background ipad
how to kill backgroung running app in ipad2
how to run apps in background ipad 2
how to turn off games that are still running on ipad
how to turn off running program ipad
how turn off. backgroungd apps on ipad
ipad 2 applications restarting
ipad 2 apps running in background
ipad 2 close running apps
ipad 3 keeping apps open after restart
ipad close apps running in background
keep apps running in background ipad
kill apps running in background
programs working in background ipad
reboot ipad 3 apps still running
