my ipad is on the slide to unluck menu but id doesnt slide and when i
try to slide to turn power off i doesn't work either any tips would be great
This is a discussion on touchscreen not working within the iPad Help forums, part of the Apple iPad Discussions category; my ipad is on the slide to unluck menu but id doesnt slide and when i try to slide to turn power off i doesn't ...
try a hard reset. Press and hold the Sleep and Home button at the same time till the Apple logo appears. This will reset the system. Then try the touch screen again. If that doesn't work then bring it to your nearest Apple store. Hopefully your iPad is still under warranty....
sorry for not getting back thanks for the tip iit did work
You're welcome. Glad i could help
