iPad charging problems
This is a discussion on iPad charging problems within the iPad Help forums, part of the Apple iPad Discussions category; Yesterday I suddenly developed problems charging my iPad. Overnight it only charged from 2% to 16% and it is losing percentage points rapidly whether it's ...
Results 1 to 4 of 4
    154982
    Jan 2012
    NH
    Yesterday I suddenly developed problems charging my iPad. Overnight it only charged from 2% to 16% and it is losing percentage points rapidly whether it's plugged into the charger or not. I have the original wall adapter but replaced the cable with a generic one. I only ever charge it from a wall outlet. I have tried a hard reset and soft reset a couple times. It says it's charging but i have to fiddle with the cable a bit for it to say it's charging. Any ideas what's wrong and how I can fix it? I've had the iPad for about 10 months btw.
  2. #2
    37823
    169 times
    Cranbrook, Kent, UK
    8,779
    If you have to fiddle with the cable I would say that is your problem.....I'd be inclined to take the cable, charger and iPad into an Apple store (if you have one nearby) and I'm sure that anything that is faulty will be replaced.
    iPad Guru
    49745
    137 times
    3,369
    Apple probably will not take responsibly for a generic cable.
    If you still have your original cable, I'd try that first.
  4. #4
    37823
    169 times
    Cranbrook, Kent, UK
    8,779
    Ah.....I missed the bit about the generic cable!
Sponsors
  1. Charging problems
    By Dianeleslie in forum iPad Help
    Last Post: 01-19-2012, 12:48 PM
  2. Charging problems.
    By ashley69 in forum iPad General Discussions
    Last Post: 10-21-2011, 02:39 PM
  3. Problems charging ipad2 when in universal docking station
    By fitzpatrick2362 in forum iPad 2 Forum
    Last Post: 06-18-2011, 10:25 PM
  4. Replies: 7
  5. Charging Problems
    By Remi in forum iPad Help
    Last Post: 02-10-2011, 12:23 AM
apple ipad 2 charging problems
fix ipad charger
ipad 2 charger problems
ipad 2 charging issues
ipad 2 charging troubleshooting
ipad 2 not charging from outlet
ipad 2 not charging outlet fix
ipad 2 not charging wall outlet
ipad 2 not charging when plugged into wall
ipad 2 stopped charging wall
ipad charging faults
ipad charging issues
ipad charging overnight
ipad not charging wall plug
ipad not charging when plugged into wall
ipad problems forum
problem charing ipad2
will any cable charger ipad
Tags for this Thread
