USB stick for document backupH
This is a discussion on USB stick for document backupH within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I have an ipad 2 with no 3G. I will be several months in a fairly remote part of India where I would like ...
Hi, I have an ipad 2 with no 3G. I will be several months in a fairly remote part of India where I would like to use it mainly for writing longish documents in Pages. My concern is backup. Without access to wi fi, or icloud, and no USB port, how can I back up my documents? In this forum and others there have been posts about the Cameral Connection Kit, but they are all aimed at people who want to import music or videos from a USB stick rather than export a document to it. Any suggestions?
Thanks, Terry
01-15-2012 09:37 PM
Originally Posted by
terryjane
Thanks, Terry
Unfortunately, you can't use the CCK to save documents to.
However, there are two products that you may want to research: Air Stash or GoFlex Satellite (by Seagate). Both of these products claim to be usable as external storage for the iPad that create their own wireless link to the iPad- no Internet required. Both of these devices have a free app in the App Store for easy access to their functions.
I've not used nor am I familiar with either one. I only know their names from what I read on the Interwebz; I don't even know the pricing or storage size. so, all I can suggest is have a good Google session.
But, maybe this'll give you an idea. Good luck and safe travels.
Black 64GB WiFi/4G iPad3 (iOS 5.1.1; jailbroken w/Absinthe 2.0) & black 64GB iPhone 4S (iOS 5.0.1; jailbroken w/Absinthe 1.0)
Thanks Marilyn, I will check them both out.
Cheers,
Terry
There is also the option of using a wifi hotspot to access cloud storage or your own ftp network attached storage.
You can purchase a stand-alone wifi hotspot and access plan (google wifi hotspot) or use a smartphone that includes a wifi hotspot.
You can also tether your iPad to a compatible phone. But, be sure your phone is compatible with the iPad. There may be extra charges for tethering. Check with your phone plan provider.
Data transfer at 3g will be slower than at 4g. So if 4g is available where you're going, consider paying the extra to have it and make sure the hardware you have will support it. Newer models of stand-alone wifi hotspots and phones usually do.
Thanks for the suggestions, but I think they are probably too high tech for me. We are talking about remote areas in India where if you even found an internet connection it would so super slow. Many areas out of the larger cities don't even have reliable 3G, never mind 4G. I need something that can back up to a USB stick or similar, and can plug into mains to be charged rather than a computer.
- You may not post replies
- You may not edit your posts
Forum Rules
By slipknot in forum iPad Help
Last Post: 09-13-2011, 10:05 AM
By trooper in forum iPad FAQ
Last Post: 07-12-2011, 04:04 PM
By Kjyjan in forum iPad Accessories
Last Post: 06-25-2011, 09:31 AM
By Maura in forum Apple iPad News
Last Post: 07-02-2010, 08:15 AM
By olsen in forum Off-Topic
Last Post: 06-30-2010, 04:11 AM
access usb stick from ipad 2
can i access my documents from usb to ipad
can i connect my usb stick to the ipad2
can ipad2 read usb stick
can ipad2 read usb stick 2012
can ipad2 use usb stick
can you backup ipad2 to a usb drive
how do i save documents from ipad 2 on usb
how to mount a usb device to ipad 2
how to save from ipad to ubs stick
ipad 3 usb stick
ipad document backup to usb
ipad usb stick
save documents from ipad 2 to usb
usb key for ipad 2
usb key ipad2
usb key to ipad
usb stick and ipad 2
usb stick ipad 2
usb stick with ipad 2
