Results 1 to 8 of 8
    1626
    Mar 2010
    Boston Ma
    23
    auto start of itunes stopped working
    All of a sudden when I attach my Ipad, Itunes will not start.(has been working since launch day of the Ipad) If I manually start Itunes all is well.
    I have confirmed that the Itunes will start when Ipad is plugged in check box is checked.
    Using the latest Itunes 9.2.0.61
    What am I doing wrong here?
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    If you are running a Windows-based machine, it might be time to give it the old three finger salute!
    1626
    Mar 2010
    Boston Ma
    23
    Quote Originally Posted by 1991-C4 View Post
    Yes running Windows 7 and the three finger salute will work, but have to do this reboot each time I connect my Ipad. Workaround for sure but not a solution to my frustrating issue.
    1626
    Mar 2010
    Boston Ma
    23
    bump,,,
    I cannot be the only one with this issue.
    Connecting my Ipad to my PC will no longer start itunes automatically. I have the setting set to do this and it was doing this for a long time.
    I am running win 7 and I know this is a apple based forum, but does anyone have a idea on how to solve this.
    7488
    Jun 2010
    189
    Is there a process dying when you disconnect? I believe in Windows there should be an iTunesHelper.exe running in task manager. Sorry, I'm at work or I could check my Vista media center.
    Also, I believe there is a setting in iTunes itself to toggle auto start on plugin.
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    Did you disable iTunes or iTuneshelper.exe in msconfig?
    http://forums.macosxhints.com/archiv...hp/t-1930.html
    1626
    Mar 2010
    Boston Ma
    23
    Quote Originally Posted by kierandill View Post
    The process will let me sync after I manually start itunes and will tell me sync is done and I can disconnect the Ipad.
    I have searched for iTunesHelper.exe, it is not listed in the task manager and I cannot find it at all on the system. Listed in the task manager is itunesmobileservice.dll which is running.
    1626
    Mar 2010
    Boston Ma
    23
    Quote Originally Posted by Matth3w View Post
    What does iTunesHelper do? [Archive] - The macosxhints Forums
    I checked and no ituneshelper in msconfig. Listed is ipod service which is running. and ipod
  1. auto brightness
    By Hawon in forum iPad General Discussions
    Last Post: 06-21-2010, 02:04 AM
  2. My iPad has stopped detecting portrait and landscape.
    By Plawrence1956 in forum iPad FAQ
    Last Post: 06-13-2010, 05:40 PM
  3. iPod app stopped working - PLEASE help...
    By cm24 in forum iPad Help
    Last Post: 05-23-2010, 08:22 AM
  4. Auto clear google search bar in safari?
    By nhenson1 in forum iPad General Discussions
    Last Post: 05-05-2010, 10:23 PM
  5. Auto Wi-Fi?
    By jimbo1mcm in forum iPad General Discussions
    Last Post: 03-16-2010, 06:53 AM
auto launch for itunes not working
auto startup itunes when iphone is plugged in
autostart itunes windows 7
how to autostart itunes on windows 7
how to make itunes start automatically on windows 7
i tunes stops running when i pad is connected
ipad autoplay itunes
ipad does not automatically open itunes
itunes does not autostart
itunes stops working when connected to ipad
itunes will not autostart
ituneshelper has stopped working
