Issues with my daughters iPad
This is a discussion on Issues with my daughters iPad within the iPad Help forums, part of the Apple iPad Discussions category; I bought my daughter an iPad 2 for Christmas. We got her iTunes account set up and updated the iOS to the 5.0.1. After the ...
I bought my daughter an iPad 2 for Christmas. We got her iTunes account set up and updated the iOS to the 5.0.1. After the sync and update of the iOS she disconnected from the computer and began using her iPad. After just a few seconds, the iPad automatically blacks out. She has to retype her password again and while doing this, the iPad blacks out again. This has happened several times and in some cases she has to turn off the iPad and restart it again just to make an attempt to log in. I have called Apple to see if they know what the problem might be and one person tells me to kill all the running programs while another actually took the time to try something and had me reset the network setting. After a few minutes of actively using the iPad again, the problem returned and it seems to have gotten worse than before. Does anyone have any suggestions? Thanks
01-11-2012 07:37 PM
It depends where you bought it, or if bought a warranty.
The iPad could be having thermal shut Downs.
You need to contact to wherever you bought it.
See if you can send the gadget to Apple Inc. and they chan check it out and do what ever they can to fix it.
But also see if your iTunes account is fully installed, and you have fully registered, and got everything done.
All I can say now is good luck.
Originally Posted by
stupidpenguine
Hi there and welcome to the forum! Sounds very frustrating for both you and your daughter. I am wondering, did you set up a password code up in order to gain access for use? I don't recall having to be asked for my iTunes password as frequent as you have described. Was she buying an app? That would ask for her iTunes password.
Also, check how long the lock/unlock switch is set for under settings. It can be set for as quickly as 2 minutes to never. These are just a few of my thoughts. You may need to be more specific with when/what she is doing when it blacks out.
Yeah, like skimonkey said, the turn of goes from 2 minutes to never.
But if she can access the main menu, you can adjust the time and maybe that will work.
The great thing about apple is that they don't leave you in the cold after buying a product. If it isn't working correctly don't hesitate to make a genius bar appointment to get a replacement.
Just be honest about the problem and I have no doubt they will replace the iPad with no hesitation. Sorry to hear about your situation.
Hi and welcome to the Forum!
Something certainly has gone haywire here. Have you done a reset of the iPad since the upgrade, if you haven't I think it would be a good idea to do one now and see if this makes a difference. Hold the power off button, the one on the top right with the ipad held in portrait, and the home button, centre bottom, simultaneously, keep holding them in and you will see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start.
Let us know how you go.
TIPS AND TRICKS - for those of us who don't know!
iOS5 Tips and Tricks
- You may not post replies
- You may not edit your posts
Forum Rules
By 5teve in forum New Member Introductions - Site Assistance
Last Post: 07-19-2011, 11:38 AM
By Al Rogers in forum Off-Topic
Last Post: 04-27-2011, 06:35 PM
By rotaz in forum iPad Hacking
Last Post: 10-27-2010, 09:32 PM
Last Post: 10-24-2010, 06:34 PM
By cimousa in forum iPad Help
Last Post: 04-28-2010, 12:09 PM
how to unlock my daughters ipad
ipad 5.0.1 problems,by date
ipad blacks out
ipad problems blacks out
menu bar kill
my daughter cannot remember her ipad password
when i set up my ipad it linked to my daughters account
