iPad won't charge when syncing
This is a discussion on iPad won't charge when syncing within the iPad Help forums, part of the Apple iPad Discussions category; It never charges when I have it plugged into my computer USB port. Is this because it requires current directly from a wall plugin and ...
Results 1 to 4 of 4
    37742
    Edmonton
    125
    It never charges when I have it plugged into my computer USB port. Is this because it requires current directly from a wall plugin and the USB port doesn't generate emough juice?
  2. #2
    147698
    2 times
    Jan 2012
    Melbourne, Florida, U.S.
    348
    I've been wondering the same thing. I remember like 2-3 years ago when i had the iPhone 3G it charged while in iTunes, so why doesn't the iPad?
    *** U.S. Federal Prisoner Transportation Services. Director of U.S. Fed. Pr. Tr. ***
    Mr. Woppit will eat you if you don't follow the forum rules!
  3. #3
    37742
    Edmonton
    125
    I see there are two threads going with this same question. I don't know if the moderators merge these threads. Short answer, computers don't generate enough power and wall charging is necessary.
    "Not Charging" .....hmmmmm....???
  4. #4
    13990
    Sep 2010
    Montgomery, NY
    181
    Because the iPad has a much higher capacity battery it requires a more powerful charger. Even though it says it's not charging on the USB port it really is but VERY slowly. It is highly recommended that you only use the Apple provided wall charger for the iPad.
    Tom
    "New" iPads-64GB 4G/WiFi and 16GB WiFi
    Pass the Kool-Aid
Sponsors
  1. Is there a way to charge ipad from PC?
    By Nay Lin in forum iPad Help
    Last Post: 02-01-2012, 12:01 PM
  2. Replies: 15
    Last Post: 09-10-2011, 10:10 PM
  3. Ipad won't charge
    By BBSean in forum iPad Help
    Last Post: 01-16-2011, 12:19 PM
  4. Syncing iPad without syncing music
    By Mike_73 in forum iPad Help
    Last Post: 01-10-2011, 03:49 AM
  5. How often do you charge your iPad?
    By kheldour in forum iPad General Discussions
    Last Post: 05-01-2010, 05:06 PM
ipad 1 not charging or syncing
ipad does not charge when syncing
ipad is not charging and sync
ipad not charging or syncing on pc
ipad not charging when sync
ipad not chraging or syncing
ipad sync and not charging
ipad will not charge or sync
ipad won't charge or sync
ipad won't charge when in use
ipad won't sync
ipad won't sync to computer
ipad wont charge or sync
ipad wont wall charge
ipad3 battery not charging from usb port
iphone 4 wont charge or sync
iphone 4 wont charge or sync 2012
iphone 4s wont charge or sync with computer
my ipad won't sync or charge
what if ipad wont sync or charge to computer
