iPad won't charge when syncing
This is a discussion on iPad won't charge when syncing within the iPad Help forums, part of the Apple iPad Discussions category; It never charges when I have it plugged into my computer USB port. Is this because it requires current directly from a wall plugin and ...
Results 1 to 4 of 4
    37742
    Edmonton
    136
    It never charges when I have it plugged into my computer USB port. Is this because it requires current directly from a wall plugin and the USB port doesn't generate emough juice?
    147698
    2 times
    Jan 2012
    Melbourne, Florida, U.S.
    347
    I've been wondering the same thing. I remember like 2-3 years ago when i had the iPhone 3G it charged while in iTunes, so why doesn't the iPad?
    *** U.S. Federal Prisoner Transportation Services. Director of U.S. Fed. Pr. Tr. ***
    Mr. Woppit will eat you if you don't follow the forum rules!
    37742
    Edmonton
    136
    I see there are two threads going with this same question. I don't know if the moderators merge these threads. Short answer, computers don't generate enough power and wall charging is necessary.
    "Not Charging" .....hmmmmm....???
    13990
    2 times
    Sep 2010
    Montgomery, NY
    184
    Because the iPad has a much higher capacity battery it requires a more powerful charger. Even though it says it's not charging on the USB port it really is but VERY slowly. It is highly recommended that you only use the Apple provided wall charger for the iPad.
    Tom
    iPad3-64GB 4G/WiFi Evasi0n JB and Mini-16GB WiFi No JB
    Pass the Kool-Aid
  1. Is there a way to charge ipad from PC?
    By Nay Lin in forum iPad Help
    Last Post: 02-01-2012, 12:01 PM
  2. Replies: 15
    Last Post: 09-10-2011, 10:10 PM
  3. Ipad won't charge
    By BBSean in forum iPad Help
    Last Post: 01-16-2011, 12:19 PM
  4. Syncing iPad without syncing music
    By Mike_73 in forum iPad Help
    Last Post: 01-10-2011, 03:49 AM
  5. How often do you charge your iPad?
    By kheldour in forum iPad General Discussions
    Last Post: 05-01-2010, 05:06 PM
ipad does not charge while syncing
ipad doesn't charge when syncing
ipad not charging on sync
ipad not charging or syncing
ipad syncs but won't charge
ipad syncs but wont charge
ipad won't charge
ipad won't charge or sync
ipad wont charge or sync
ipad wont charge while syncing
iphone 4 wont charge or sync
why doesn't my ipad charge when syncing
