Side Switch - The settings
This is a discussion on Side Switch - The settings within the iPad Help forums, part of the Apple iPad Discussions category; Side Switch: I used to have an unlocked rotation and sound on my iPad2. Apparently now you can only put your settings to mute or ...
Results 1 to 10 of 12
Like Tree1Likes
Thread: Side Switch - The settings
    149606
    Jan 2012
    8
    Question Side Switch - The settings
    Side Switch:
    Apparently now you can only put your settings to mute or rotation, and the Side Switch does not allow rotation and sound or locked rotation and mute sound simultaneous. It simply mutes your sound if you set your rotation to unlocked or lock your rotation if you choose the mute settings.
    How to solve this problem?
    Rotation and Sound.
    Rotation and muted Sound.
    Locked Rotation and muted Sound.
    Locked Rotation ans Sound.
    Those settings should be possible, but how
    13576
    751 times
    Aug 2010
    Western NY state (USA)
    9,313
    If you double click on the Home button, a multitasking bar will be revealed. Swipe towards the right (to bring stuff on the left side into view). When the left "page" appears, the leftmost icon is the icon you need to do the opposite of the hard switch setting.
    So, if your switch is set for mute, the icon will stop the rotation. If your switch is set to stop rotating, the icon will enable muting.
    Hope this helps.
    149606
    Jan 2012
    8
    Dear Marilyn, your hope is in vain - Apple has a nice page describing the function of the side switch.
    If you read my first posting I do have a problem with putting the settings to mute or rotation, because the Side Switch does not allow rotation and sound or locked rotation and mute sound simultaneous anymore. It simply mutes your sound if you set your rotation to unlocked or lock your rotation if you choose the mute settings.
    Did anybody noticed this too, or am I the only one having this problem?
    13576
    751 times
    Aug 2010
    9,313
    Quote Originally Posted by DickVanGelder View Post
    [The side switch] simply mutes your sound if you set your rotation to unlocked or lock your rotation if you choose the mute settings.
    This is a true statement, which is why Apple designed the icon (in the multitasking bar) to complement the hard switch. I think we're talking cross purposes here - or I'm not explaining it well enough. Let me try again:
    * If you have the side switch set to stop/start rotation, using the icon in the multi-tasking bar will mute/un-mute the ipad
    -- OR --
    * If you have the side switch set to mute/un-mute, using the icon in the multi-tasking bar will stop/start rotation
    Whatever setting you choose for the side switch (in Settings > General > Use Side Switch to: ), be it Lock Rotation or Mute, the multitasking icon will automatically be programmed to do the other option.
    You have to use these two together to get all the different permutations of rotating and muting. The side switch alone will not do this (and neither will the multitask bar icon); they complement each other to have the feature the other lacks.
    Does that help any better?
    ukplaya likes this.
    149606
    Jan 2012
    8
    Dear Marilyn, thanks for your quick reply but it still does not explain how I can get back to my previous situation where rotation was on and the sound was not muted. A lot of apps simply can not function well without sound and locked rotation...
    151077
    Jan 2012
    Brisbane, Australia
    Hi,
    Really stuck now - I just updated to IOS5 on the ipad. All of a sudden, I now don't have sounds on the apps. Movies ok, music ok - but nothing on the Apps. Help please???
    149606
    Jan 2012
    8
    Quote Originally Posted by Mickey330
    That is just my point. I can have unlocked rotation and sound or muted sound and rotation, but I used to have those functions before.... Should I reset to factory settings ? :-(((
    149606
    Jan 2012
    8
    That is just my point. I can NOT have unlocked rotation and sound or muted sound and rotation, but I used to have those functions before.... Should I reset to factory settings ? :-(((
    Sorry the NOT disappeared, ;-)
    13576
    751 times
    Aug 2010
    9,313
    I am sorry to be so dense, but I am truly not understanding your problem. On my iPad, I can set it so that the rotation is unlocked AND I have sound. Or, I can have rotation and the iPad is muted.
    My side switch is set to prevent rotation. So, to mute the device, I access the Mute icon in the multi-tasking bar and mute (or un mute) the sound. These two things (the switch and the icon) make it so you can have all four combinations:
    1) Sound off; rotation stopped
    2) Sound on; rotation stopped
    3) Sound off; rotation allowed
    4) Sound on; rotation allowed
    See this picture for what I am talking about; what I am able to do:
    If you cannot do this (access the multitask bar icon to allow you to do any one of the four configurations), and you are on iOS 4.3 or higher - then yes, your iPad is not behaving properly and I would recommend a restore.
    Again, I apologize for not getting what you are saying - I feel as if we are in an Abbott & Costello skit! Sorry.
    iPad Ninja
    32446
    22 times
    Feb 2011
    Australia
    1,626
    A picture tells a thousand stories .
    Well explained
    Greetings from paradise,on my iPad
  1. Side by Side version 1.2 release (with promo codes)
    By 1234 in forum iPad App Announcements
    Last Post: 04-07-2013, 01:13 AM
  2. Replies: 10
    Last Post: 12-26-2011, 11:51 PM
  3. Side switch set to Mute but not muting videos?
    By dlo in forum iPad 2 Forum
    Last Post: 11-26-2011, 10:54 PM
  4. Split Screen/Side by Side
    By jasmynsway in forum iPad Apps
    Last Post: 05-03-2011, 09:21 AM
  5. Use ipad side switch for wifi on/off??
    By Kabona in forum iPad Hacking
    Last Post: 04-28-2011, 10:00 AM
how do i unmute my ipad
how do i unmute my ipad 2
how to enable side switch on iphonem5
how to unmute the side switch
how to use side to unmute ipad
ipad 2 switch on side
iphone 4s side switch settings
iphone 5 side switch settings
iphone side switch settings
side switch iphone 4 settings
what is the switch on the side of my i pad
