I got the Apple composite av cable to connect the iPad ti tv...but cannot figure out the settings for the iPad...has anyone done that yet?
This is a discussion on Connecting an iPad to tv within the iPad Help forums, part of the Apple iPad Discussions category; I got the Apple composite av cable to connect the iPad ti tv...but cannot figure out the settings for the iPad...has anyone done that yet?...
Not have one but i would think the ipad would be auto like the cam conection. Have you got the tv set up to the right channel.as in av1 av2 and such. other to that someone eles might have the connection. good luck.
I have one. What are you trying to view on the tv? It will only output movies, photos or Netflix streaming to the tv. It won't display your home screen or Safari or games, etc.
There are no settings needed for the iPad, but as littlebuddha says, you need to get the tv input matched up to what you plugged the cables into. Check for labels where you plugged the cables into. It will either be AV1 or AV2, etc. Then select that same source on your tv menu.
iPAddict - 16Gig WiFi with Zagg InvisibleSHIELD Front - clear Hard Candy Sleek case - Built NY sleeve - Freedom Pro folding Bluetooth keyboard - Microsoft Bluetooth 6000 keyboard - Boxwave stylus - DIY LEGO stand, 3feet stand & DIY fold-flat stand
yeah only the videos/photo's display out to the TV.
If you have jailbroken your iPad download the TVOut2 app and it will display everything on the TV.
Built in Video and the Netflix app will work. I haven't tried YouTube. For me, YouTube videos don't need to be displayed that big.![]()
I want to use ipad with netflix and put through my tv. It says on netflix that I have to "activate my netflix ready device." I'm supposed to be able to get the activation code on the ipad, but it doesn't show, even when connected to the computer as required. Anyone know how to get the activation code from the ipad?![]()
