New problem: Movie format not supported
This is a discussion on New problem: Movie format not supported within the iPad Help forums, part of the Apple iPad Discussions category; Made the mistake of letting kids play with the IPad, now movies and music that had previously played on IPad no longer works. When trying ...
Results 1 to 3 of 3
    145802
    Jan 2012
    Michigan
    Question New problem: Movie format not supported
    Made the mistake of letting kids play with the IPad, now movies and music that had previously played on IPad no longer works. When trying to play a movie "the movie format is not supported " prompt comes up. When trying to play music, no prompt comes up but it just doesn't play. Never had this problem before, so wondering if the kiddos did something. Any one have any suggestions I could try to fix this? would appreciate it very much! Thanks!
    Jamie
    579 times
    Dayton, WA
    13,189
    Try the usual fixes and see if one of them work.
    Supporting Vendor
    95402
    3 times
    Sep 2011
    429
    it's strange, are you sure the movies played well on ipad previously? hope twerppoet's reply will solve your problem
  1. Video format (format, filesize, resolution) recommendations for iPad
    By bat0nas in forum iPad General Discussions
    Last Post: 02-16-2013, 09:43 AM
  2. What Video format is supported by iPad2
    By Paul80 in forum iPad 2 Forum
    Last Post: 11-16-2011, 05:50 PM
  3. Are subtitles supported in mp4 in the default iPad movie players?
    Last Post: 10-02-2011, 06:13 AM
  4. Problem in converting movie..PLEASE HELP!!
    By brodhawg in forum iPad Help
    Last Post: 05-02-2011, 05:45 PM
  5. What is best movie format for iPad2
    By nealh in forum iPad 2 Forum
    Last Post: 03-20-2011, 08:52 PM
ipad movie format not supported youtube
ipad this movie format is not supported
ipad youtube movie format not supported
movie format not supported ipad
the movie format is not supported ipad
this movie format is not supported ipad
this movie format is not supported youtube
youtube ipad movie format not supported
youtube ipad this movie format is not supported
