Suddenly the ipadscreen wwon't rotate anymore!
This is a discussion on Rotation within the iPad Help forums, part of the Apple iPad Discussions category; Suddenly the ipadscreen wwon't rotate anymore!...
Check the little round button next to the volume control.
I know that button, but that doesn't solve the problem.
Hello and welcome to the forum!
I'm assuming that you've tried the following: 1) Open the multitask bar (double tap home button), move to the left end and see if the screen setting is locked; 2) Go into settings and change the side switch back & forth between sound vs. screen lock - retest?
If those maneuvers do not help and if not already done, 'Restart' and if not successful 'Reset' the iPad - directions HERE, if needed. Good luck and please post back here if assistance is still needed!
