Results 1 to 3 of 3
    142486
    Dec 2011
    Tasmania, Australia
    6
    iTunes established on PC but the iPad is a problem!
    Can anyone please help with the following problem?
    I have a PC on which I have loaded itunes.
    I now whish to use itunes on my iPad.
    When i press the iTunes icon on my iPad I get a blank screen with the text "ITunes Store Terms and Conditions" showing on an otherwise blank screen.
    When I press on this text I get a set of countries and when I press on Australia (my location) I get a long list of conditions - but there is no button to click agree.
    It seems this is important since, when I press the Music icon, the screen opens up, only to close after a number of seconds. I am assuming that this is because I have not agreed to the Terms and Conditions
    Can anyone help?
    {a peculiar thing is that the iPad recognises my purchases - under Purchases of course in iTunes}
    Peter
    37823
    539 times
    Cranbrook, Kent, UK
    15,671
    That sounds like you are on the Downloads tab. If you have no current downloads then that is the screen you get when on that tab. All your other tabs should work so you should be good to go.
    If you are looking for your music/videos then they will be in the Music App and the Videos App. iTunes on the iPad is only a front end for the iTunes Store.
    142486
    Dec 2011
    Tasmania, Australia
    6
    You are correct ... I was on that tab! I thought it was telling me I had to agree to the conditions!
    Thank you - I messed around in the Purchased tab and noticed that there were indications to download what I had purchased on the PC ... for some reason I had assumed that they were automatically downloaded for me ... but NO!
    After downloading my revious purchases, I was able to play them under the Downloads tab!
    You enabled me to get away from my obsession with agreeing to some contract ... thanks so much for that!!!
    Peter
  1. Problem when syncing ipad with itunes
    By rdefino in forum iPad 2 Forum
    Last Post: 09-27-2011, 03:01 PM
  2. Problem with new iPad connecting to Itunes
    By iPadIssues in forum iPad Help
    Last Post: 12-28-2010, 11:19 PM
  3. Itunes and ipad problem
    By underwaterboy in forum iPad Help
    Last Post: 11-26-2010, 05:24 AM
  4. Problem with iTunes app on iPad
    By dkinion in forum iPad Help
    Last Post: 07-01-2010, 04:44 PM
  5. Problem with connecting Ipad to Itunes
    By Rogner in forum iPad General Discussions
    Last Post: 06-23-2010, 07:52 AM
ipad downloads itunes store terms and conditions
ipad downloads says itunes store terms and coniditions
ipad itunes store terms and conditions downloads
itunes download tab shows terms and conditions
itunes terms and conditions ipad problem
itunes terms and conditions problem
my ipad has the itunes store terms and conditions on downloads tab
when is the ipad established
