Networking and WiFi Question
This is a discussion on Networking and WiFi Question within the iPad Help forums, part of the Apple iPad Discussions category; I have a desktop [iTunes installed, waiting for iPad, Fri] with no WiFi. DSL connection through modem/router. I also have a netbook that has WiFi ...
Results 1 to 8 of 8
    6931
    Jun 2010
    Beavercreek, Ohio (Dayton PO
    174
    Talking Networking and WiFi Question
    I have a desktop [iTunes installed, waiting for iPad, Fri] with no WiFi. DSL connection through modem/router. I also have a netbook that has WiFi and can also connect to my m/r through cable connection.
    Soooo.... my question is: If I connect my netbook to the m/r and turn on WiFi, can I use the netbook as a hotspot in my house? Connect to the DSL through the netbook WiFi?
    I am not sure how all these things would see/connect.
    I don't have any other WiFi device to have it pretend to be the iPad or I would try it rather than ask.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Quote Originally Posted by mslammers View Post
    No. You need to buy a wireless router which is something that transmits a WiFi signal. Your netbook is meant to receive WiFi signals.
    6307
    Jun 2010
    Sierra Vista, AZ
    17
    actually you can setup internet connection sharing (or something like that) on the laptop and you can connect through it.
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Can you? Yes
    Should you? No
    it can be done how you want with the actian as a hotspot via software or by enable internet connection sharing. But this is not a verry reliable way to share the internet and can be complicated if you dont know what to do.
    The best option would be to just buy a wirelss router to replace your current router. They have come way down in price and you can get one now for under $30
    iPad Enthusiast!
    7784
    Jun 2010
    South Africa
    30
    Actually, I would say that you only need a wireless Access Point (not a router) since the router functionality is already built into your cable modem / router. These are usually fairly cheap and I'm sure you'll have no problem finding one at your local computer store.
    You didn't say how many ethernet ports your cable modem has, if it only has one or has none free then make sure that you get a wireless AP with 2 or more ports, so that the AP connects into the cable modem and you can plug something else into the AP. Again, I'm sure your local computer store will be able to assist you.
    Cheers
    Dale
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by dale600rr View Post
    Cheers
    Dale
    The majority of all access points only come with one ethernet port because thats all an AP requires. Since he is using a wired pc as well its better to get a wireless router.
    Wireless routers on the have built in switch's with at least 4 ports for connecting multiple wired devices. They also ad a layer of security with their built in firewall capabilities.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Quote Originally Posted by MikesTooLz View Post
    Well then I stand correct on being able to use your laptop to connect, but I did want to add that I bought a D-Link wireless N router from BestBuy for $20! It was a mail order only deal so I had to add a couple of bucks for shipping but it was still less than $30.
    Our house sits roughly in the middle of a 3 acre piece of property and I can stick my iPod Touch in my pocket and listen to streaming audio anywhere I go without cutting out. It sure helps the monotony of cutting all what grass!
    6931
    Jun 2010
    174
    I got a new wireless router/DSL modem with 4 ethernet ports. Tested it with my WiFi netbook and it works fine. Firewall, too. Matches capability of my previous w/r.
    Thanks for the advice and knowledge. I suspected my idea would not be really good.
    Mel Lammers
  1. Setting up Verizon Blackberry Tour Wifi Hotspot for Ipad Wifi
    By xlr8nflorida in forum iPad General Discussions
    Last Post: 06-14-2010, 11:09 PM
  2. Wifi - Faster on Wifi model than 3G model?
    By mjeagent in forum iPad General Discussions
    Last Post: 06-11-2010, 12:13 PM
  3. Wifi vs 3G wifi speed/reception
    By CPMS in forum iPad General Discussions
    Last Post: 05-03-2010, 10:25 AM
  4. WiFi VS. WiFi + 3G WiFi Issues
    Last Post: 05-01-2010, 12:26 PM
  5. WiFi VS. WiFi + 3G Release
    Last Post: 03-11-2010, 01:48 AM
arris dg860
arris dg860 connection problems
arris dg860 default password
arris dg860 no wifi
arris dg860 no wireless
arris dg860 wifi
arris dg860 wifi not working
arris dg860 wifi problem
arris dg860 wifi problems
arris dg860 wireless not working
dg860 password
