Results 1 to 2 of 2
    140142
    Dec 2011
    Slideshow app problem
    As I was writing a presentation in the app Slideshow, the menu icons (settings, view slides, and slideshow menu) disappeared, and I don't know how to reset the program or make them reappear. Does anyone know how to reset the programs or restore settings on the program? I've only had an iPad for about a month, and I'm not that technically skilled yet.
    622 times
    Dayton, WA
    13,310
    I don't have that app, but I suggest the usual fixes, if you haven't already tried them.
  1. Photo Slideshow
    By cabinowner in forum New Member Introductions - Site Assistance
    Last Post: 11-09-2011, 02:54 AM
  2. Slideshow builder
    By LoadsaaaTOP in forum iPad Apps
    Last Post: 07-21-2011, 05:33 AM
  3. video slideshow
    By patndan in forum iPad Development
    Last Post: 01-10-2011, 06:12 AM
  4. Photo Slideshow
    By ipadguy77 in forum iPad Help
    Last Post: 12-14-2010, 12:04 PM
  5. Slideshow for photos
    By Hotdog1958 in forum iPad Help
    Last Post: 11-03-2010, 03:06 PM
forgot slide show apps
image slideshow on ipad issues
ipad slide show problems
ipad slideshow app
ipad slideshow problem
ipad slideshow problems
ipad slideshow provlems
ipad slideshow settings
problem in slide show in ipad
slide show
slideshow not working on ipad
writing a slideshow app
