How do you keep your pictures from being in a random order when you select slide show on iPad?
This is a discussion on Picture order within the iPad Help forums, part of the Apple iPad Discussions category; How do you keep your pictures from being in a random order when you select slide show on iPad?...
De-select "shuffle."
You cant really change how they are sorted but they should not be in random order. They should be ordered by oldes at the top to newest at the bottom.
Soooo... if the iPad is sorting by date, can you change the date through modifying the older file names and reloading since the new files would have a different dates?
Some form of organisation for photos is desperately needed. Let's hope apple will include some tweaks for the forthcoming upgrade.
I had some web images I saved and forwarded via email. They are now "saved" and no obvious way to delete them. Aargh!
