This is a discussion on Picture order within the iPad Help forums, part of the Apple iPad Discussions category; Originally Posted by epb Originally Posted by Hasty Some form of organisation for photos is desperately needed. Big time. My slideshow/screensaver is pictures of all ...
I had the pictures in the correct order in my album before I uploaded them and when I select "photos" on the iPad they are in the correct order BUT when I select "slide show" on the iPad they are out of sync. How did you re-order your pictures?
I was as frustrating as you guys out there trying to keep the pictures in order through sync process. I use photo presentation for my work which is compilation of different time and subjects. . I accidentally discovered that if you zip all your pictures in one folder and upload it to your ipad. The slide sequence would remain the same as you intented. The reason is that ipad sort it with time line when you sync the pictures. I think when you zip and unzip the file, it removes or change the original time line (when the pictures was taken) of the pictures. The ipad would arrange the photo as its unzip sequence as you put it in the folder.
