Audiobook keeps starting from the beginning.
This is a discussion on Audiobook keeps starting from the beginning. within the iPad Help forums, part of the Apple iPad Discussions category; I am trying to listen to an audiobook I purchased from iTunes using the Music App. I am using an iPad 1 and the latest ...
Results 1 to 4 of 4
    62356
    Jun 2011
    I am trying to listen to an audiobook I purchased from iTunes using the Music App. I am using an iPad 1 and the latest operating system.
    The first audiobook I bought just worked and always started where I left off. This is the second one and it keeps restarting from the beginning, which is a bit annoying because I don't always finish at a chapter break.
    The App remembers for a while but if I have listened to a podcast or anything in between it forgets.
    Is this a problem with the book?
    Is there a specific way I should exit the audiobook to cause it to remember where I left off?
    Have I somehow changed the settings? I can't find anything in the settings
    Regards
    577 times
    Dayton, WA
    13,181
    If the book's media kind is not set to Audiobook, it will be treated as a standard music file.
    If you sync with iTunes on the computer and the audio book is there, right click on it, choose Get Info, and make sure the Media Kind is set to Audiobook in the Options tab. If not, set it so and sync it back to the iPad.
    I don't know of any other way but iTunes to change the media kind, or another reason why your audio book might not work properly.
    62356
    Jun 2011
    Both iTunes and Music recognise it as an audiobook.
    Unlike the previous book I downloaded the book straight to my iPad and not to my desktop computer.
    So I synced the iPad ( I don't do this often so it takes some time) and the book is now in iTunes on my desktop. I checked the options, they seemed be correct but I reset it to make sure start from where I left off was set and I then synced the iPad again.
    This has not solved the problem. Music only remembers the place as long as I don't use the App to listen to anything else.
    577 times
    Dayton, WA
    13,181
    Sorry. I'm out of ideas then, other than the usual remedies (which I will post below). I don't think they will help, but it won't hurt to try them.
  1. AppStore - back to the beginning
    By Dov in forum iPad Help
    Last Post: 09-07-2012, 01:08 AM
  2. Audiobook
    By Kilroy47 in forum iPad Help
    Last Post: 06-20-2012, 02:07 AM
  3. [Dev Story] UNNYHOG : The Beginning
    By unnyhog in forum iPad General Discussions
    Last Post: 12-08-2011, 07:07 PM
  4. App Store browsing from ipad keeps starting at beginning
    By babrams in forum iPad General Discussions
    Last Post: 05-10-2011, 09:16 AM
audio book keeps starting at beginning
audiobook keeps restarting
hold place itunes audiobook
how to hold place on audiobook on an ipad
how to keep my place on ipad audiobook
iphone audio books start from beginning
iphone audiobook keeps restarting
iphone keeps restarting to beginning playlist
listening to audiobooks on music on iphone 5 the chapter resets to beginning
my audiobbooks restart on my iphone 5
why does my iphone audiobook keep starting over
why doesnt iphone hold place in audio book
