Wireless connection issue with wifi sync and when using Air Video on my iPad...
This is a discussion on Wireless connection issue with wifi sync and when using Air Video on my iPad... within the iPad Help forums, part of the Apple iPad Discussions category; Hi, This is a bit of a long winded issue, basically I have a Sky broadband router which is next to useless in its wireless ...
Results 1 to 1 of 1
    135278
    Dec 2011
    Hi,
    This is a bit of a long winded issue, basically I have a Sky broadband router which is next to useless in its wireless connection. I have a 2nd wireless access point which helps me get wireless connection BUT when I use it to connect both wifi sync and Air Video no longer work. Wifi sync won't allow connection between my iMac and iPad, it's as if they can't see each other. I assume there are some settings I need to adjust on the access point, maybe opening up certain ports on the router to allow the access point to work properly. If anyone has any suggestions I would really appreciate it, I am running version 10.6.8 of OSX and I have version 5.0.1 on my iPad and the latest version of iTunes so everything is up to date.
    Many thanks,
    Jamie.
  1. Replies: 1
    Last Post: 10-14-2011, 10:02 AM
  2. Replies: 4
    Last Post: 05-29-2011, 10:16 PM
  3. Ipad connection issue
    By Skynetkernel in forum iPad Help
    Last Post: 04-08-2011, 11:11 PM
  4. Replies: 3
  5. Replies: 2
    Last Post: 05-06-2010, 04:20 PM
air video cant connect
air video ipad cannot connect to pc
air video ipad won't connect
air video not working on ipad
air video won't connect
cannot connect to air video on work wifi
cant connect air video
cant connect with air video
connect to air wifi ipad
how to connect airvideo to wifi
ipad wifi sync not working sky router
ipad won't connect to air video
