Ipad 2 wifi problem
This is a discussion on Ipad 2 wifi problem within the iPad Help forums, part of the Apple iPad Discussions category; Hi guys.. i have an iPad2 and iam facing wifi problems...my wifi shows full signal strength and still i am not able to open websites ...
Results 1 to 10 of 10
    136268
    Dec 2011
    India
    Ipad 2 wifi problem
    Hi guys..
    i have an iPad2 and iam facing wifi problems...my wifi shows full signal strength and still i am not able to open websites using safari.
    the youtube app also does not work sometimes.
    it was working perfectly from the last 8 months but suddenly i am facing these issues.
    i have tried reseting network settings changing wifi passwords from wep to wpa and all other available passwords...still the problem is not solved..
    i have a macbook air and htc phone both work perfectly.
    help me out guys its really frustrating
    48665
    960 times
    Brisbane, Australia
    23,550
    Hi and welcome to the Forum!
    With regard to your wifi troubles have a look here
    http://support.apple.com/kb/TS1398
    Sometimes it's a good idea just to restart your iPad, have you done this?
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    136268
    Dec 2011
    India
    i have tried to restart my iPad..i have tried all the troubleshooting tips given by apple.
    issue is still not solved.
    1544 times
    Walla Walla, WA
    15,464
    Restart the router. While it is off, reset the network settings on the iPad, as you did before. When the router comes back online try logging into the network again. Sometimes routers decide they don't like the iPad anymore and need to come down with a case of amnesia. This can happen even if every other device on the network is working fine.
    Here is another thread with tips for troubleshooting iPad network problems.
    Unable to connect to Wi-Fi
    48665
    960 times
    Brisbane, Australia
    23,550
    Quote Originally Posted by twerppoet
    Thank you Twerppoet, you've come to the rescue yet again!
    1544 times
    Walla Walla, WA
    15,464
    Only if it works.
    136268
    Dec 2011
    India
    still the problem is not solved....i am now facing the same wifi issue of loosing connection while showing full signal strength on macbook air also.
    there might be a problem in my router....i have a netgear 450 BX1 router....please tell me how to know about current firmware or how to upgrade the firmware
    1544 times
    Walla Walla, WA
    15,464
    To update your router firmware you need to visit the manufacturers site and look for their support and/or downloads pages. Each router/manufacturer goes about things differently. Since I don't use your router, that's about all I can tell you. Sorry.
    94993
    Sep 2011
    9
    I assume you are on iOS5. I had untold wifi troubles before I upgraded. I seldom have problems since the upgrade.
    Good luck, Ian
    136268
    Dec 2011
    India
    I am on ios 4.3.3 jailbroken
  1. Monopoly hd app for iPad 2 wifi problem
    By Debz in forum iPad Games
    Last Post: 12-18-2011, 02:13 AM
  2. Problem with Wifi connectivity with my iPad
    By zoombieland in forum iPad 2 Forum
    Last Post: 11-04-2011, 10:06 AM
  3. iPad 2 wifi problem
    By alex.cavers in forum iPad General Discussions
    Last Post: 08-28-2011, 02:22 PM
  4. Replies: 1
    Last Post: 05-04-2011, 02:18 AM
  5. wifi problem on ipad
    By nikko1000 in forum iPad FAQ
    Last Post: 10-11-2010, 07:42 PM
ipad 2 wifi not working
ipad 2 wifi problem
ipad 2 wifi problems
ipad 2 wifi sorunu
ipad2 wifi not working
ipad2 wifi problem
wifi not working on ipad 2
wifi on ipad 2 not working
