Results 1 to 2 of 2
    9186
    Jul 2010
    United States
    8
    ddropped iPad and repair
    A couple of weeks ago I dropped my iPad one on a tile floor. It worked fine after. However, about a week later, I went to turn it off and found the metal case was bent and the on/off button would not work. Its a 64G with wifi. A apple offered my $419 toward the same model which is a refubished one I assume. To get it fixed I can replaace the back for $150. If they break the gas when the remove the back the cost goes to $300. I planned to get an iPad 3 when they come out and pass this along to my grandson. If I cannot turn it off, does anyone have any idea how this will affect the battery life.
    Right now I'm leaning toward not having it repaired. I'd appreciate thoughts as to what others would do. I would like my grandson to be able to use it for a while.
    Thanks for any suggestions.
    31439
    9 times
    133
    Rule of thumb for repairing anything is if it costs more than half it's value to repair, get a new one, else go ahead with the repair. I had my 1G repaired over almost exactly the same problem. I had to ship it to another city and got it back promptly with the case bent back into shape.
    Alternately you could just go to settings and set the sleep time to two minutes if you're concerned about battery life. I never turn mine off, but you need the power button for screen shots and resets.
  1. Has Anyone Attempted an iPad Repair?
    By Hellion in forum iPad DIY
    Last Post: 06-19-2012, 09:15 AM
  2. Sending ipad for repair
    By dartg8tr in forum iPad Help
    Last Post: 11-02-2011, 04:55 AM
  3. iPad repair
    By djwil in forum iPad General Discussions
    Last Post: 10-20-2011, 05:15 AM
  4. iPad Repair?
    By WarreNi4 in forum iPad General Discussions
    Last Post: 01-25-2011, 05:26 AM
  5. Damaged iPad & repair
    By DuggerOregon in forum iPad General Discussions
    Last Post: 07-31-2010, 08:33 PM
bent ipad case
casing bent on ipad
dropped ipad repair
fix bent ipad
ipad bent case
ipad case bent
ipad case repair
ipad metal bent
ipad metal repair
ipad repair forum
repair bent ipad
repair ipad case
