Double letter when typing.
This is a discussion on Double letter when typing. within the iPad Help forums, part of the Apple iPad Discussions category; My I pad 1 has a peculiar problem when touching the letter a on the keyboard. When I tap on the letter "a" normally like ...
Results 1 to 6 of 6
    131957
    Dec 2011
    Cambridge, Canada
    5
    My I pad 1 has a peculiar problem when touching the letter a on the keyboard. When I tap on the letter "a" normally like any other letter or key, it tends to give me a double letter "aa" and I have to back space and remove the second letter. Has anyone else had this issue and if so how did you fix this problem?
    13576
    1447 times
    Aug 2010
    Western NY state (USA)
    11,055
    I have never had this problem on my iPad. Not that that means anything - one anecdote is not data!
    So, try the old "kick the iPad in the software" trick to see if you can make it behave better. This means to do either a restart or a reset. Here's how:
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    Try either (or both!) of those and see if that fixes your problem. Good luck and let us know how you get on.
    131957
    Dec 2011
    Cambridge, Canada
    5
    Thanks for the suggestions and I have tried the reset but to no avail, the problem keeps coming back. I will keep working at it until we find the answer
    13576
    1447 times
    Aug 2010
    11,055
    Oh, sorry the restart/reset option didn't help. That's all I had.
    Maybe a trip to the Genius Bar at an Apple Store may be of benefit?
    Good luck (and thanks for the update - Lthough it didn't help).
    131957
    Dec 2011
    Cambridge, Canada
    5
    Quote Originally Posted by Mickey330
    I will check that out!
    283678
    Mar 2013
    Iowa
    Same issue with mine. With the letter "eee". This is a sample of it happening. Ipad 4th generation. Sporadic and veery annoying.
  1. Replies: 2
    Last Post: 07-09-2011, 08:57 PM
  2. Replies: 1
    Last Post: 04-10-2011, 09:41 AM
  3. The letter 'I' to capitalise
    By Brindley in forum iWork Forum
    Last Post: 04-08-2011, 10:06 AM
  4. How many words can you think of per letter
    By Rocky in forum Off-Topic
    Last Post: 01-22-2011, 07:32 PM
  5. delete a letter !
    By Andy Loba in forum iPad General Discussions
    Last Post: 11-08-2010, 12:38 PM
ipad double capital when typing
ipad double letters
ipad keyboard double letters
ipad keyboard double typing letters
ipad typing double letters
why does my ipad duplicate letters?
why does my iphone 5 type double letters
zagg keyboard double letters
