NO SIM Help Please
This is a discussion on NO SIM Help Please within the iPad Help forums, part of the Apple iPad Discussions category; I've been using my iPad 2 for about seven months, with no real problem. The other day, I closed the case and came back a ...
Results 1 to 3 of 3
    54939
    May 2011
    clifton park, new york
    NO SIM Help Please
    The other day, I closed the case and came back a few hours later and suddenly had no
    internet 3G access. My ATT account is current. After a few checks, in settings I noticed the
    cell line was pale and had the words "no SIM" next to it. I couldn't click on it.
    THe iPad didn't fall or get banged. It just says no SIM. The wifi is working fine but
    not the 3G. I restarted it to no avail a couple of times. So, I have to admit I don't even
    know what a SIM is or why I suddenly don't have it but I sure miss the 3G aspect of my iPad.
    Can anyone help"?
    thanks in advance for any thoughts.
    111434
    316 times
    Oct 2011
    Near the Ionian Nebula, still searching for Earth
    8,367
    The SIM card is what lets you connect to your 3G service. Hold your iPad with the HOME button at the bottom. On the left side is a narrow pop-out slot. Has a little hole in it.
    Your iPad came with a key.....
    Use it to open the SIM slot. Take out the SIM card and re-seat it, close and see if you get connectivity. If you don't the SIM could be baked. They're mass produced and some are duds.
    Good luck.
    iPad Wizard
    49745
    369 times
    6,587
    Sometimes SIM cards go bad. If that's the case with yours, your carrier should replace it for free.
ipad 3 says no sim
ipad saying no sim
ipad says no sim
ipad says no sim card
ipad shows no sim
ipad suddenly says no sim card
my ipad 2 says no sim
my ipad says no sim
when ipad says no sim
why does my ipad say no sim
why ipad says no sim
why is my ipad saying no sim
