Ibooks problem
This is a discussion on Ibooks problem within the iPad Help forums, part of the Apple iPad Discussions category; Hi, i am new here and i hope this is the right pllatform for me to ask for help. Previously I've got an apple ID ...
Results 1 to 4 of 4
Thread: Ibooks problem
    106837
    Oct 2011
    Ibooks problem
    Hi, i am new here and i hope this is the right pllatform for me to ask for help. Previously I've got an apple ID that i used but have seized to use it for quite a while and been using a new ID since then. However with the recent ibooks update, the ibooks app that i have was downloaded using my old id. Tried updating it but it won't work and after trying quite a while, i decided to delete and re installed it with a new id. Problem that i have is that, it'll have the ibook icon and the waiting status but after a few seconds, it'll just dissapear...tried a couple of times and the same thing happened. Tried re booting it and it still doesn't work...have quite a few documents inside and i hope to install it and recover the docs from icloud..anyone kind enuff to help me with the ibooks installation...thanking in advance..
    576 times
    Dayton, WA
    13,177
    At the bottom of most iBook Store pages/tabs you will see a button with your Apple ID (or SignIn). You can tap this button to log out of the store and back in with the other Apple ID. It only affects that store. Your iTunes and App Store logins are separate, and changed the same way.
    106837
    Oct 2011
    Ok, thanks for the info...
    576 times
    Dayton, WA
    13,177
    No problem. Hope it helped.
  1. A problem with iBooks
    By austy in forum iPad Help
    Last Post: 10-04-2011, 03:01 PM
  2. iBooks Problem
    By Fez in forum iPad Help
    Last Post: 08-24-2011, 05:21 AM
  3. Sync iBooks Problem
    By jasonhooper in forum iPad Help
    Last Post: 07-29-2011, 12:02 AM
  4. Ibooks problem
    By nmpettus in forum iPad Help
    Last Post: 05-02-2011, 09:57 AM
  5. iBooks FIX iOS 4.2.1 Jailbreak DRM Problem
    Last Post: 02-17-2011, 03:00 AM
ibook problem
ibook problems
ibook update problem
ibook won't download
ibook won't update
ibooks icloud problems
ibooks problem
ibooks problems
ibooks update problem
ibooks won't update
ibooks won't update on ipad
why won't ibooks update
