Syncing 2 iPads on the same computer
This is a discussion on Syncing 2 iPads on the same computer within the iPad Help forums, part of the Apple iPad Discussions category; Hi all, I'm currently using an iPad 1 with iOS 4.3, and my father is considering buying an iPad 2. My question is will there ...
Results 1 to 5 of 5
    1840
    Apr 2010
    22
    Hi all,
    I'm currently using an iPad 1 with iOS 4.3, and my father is considering buying an iPad 2. My question is will there be any problems syncing both iPads on the same PC? Will iTunes be able to differentiate between the 2 iPads and keep the apps separate?
    Thanks!
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    No problems at all. You can sync lots of Apple devices to the same PC. I have 2 iPads and 3 iPhones sync'd to my MacBookPro without any issues.
    What you can't do is sync your iPad with multiple desktops...
    1840
    Apr 2010
    22
    Thanks!
    iPad Wizard
    49745
    370 times
    6,602
    Just give the devices different names and click off anything you don't want to automatically synch.
    When I've done it, I usually restore the new iPad to the profile of my earlier one, then rename it, and delete what I don't want. That's if you want most of the content and apps on the new one as well, to save time loading, but YMMV.
    1840
    Apr 2010
    22
    Quote Originally Posted by Kaykaykay View Post
    Thanks for the suggestion! I'll try that.
  1. Two different iPads, one computer
    By Stormyone in forum iPad General Discussions
    Last Post: 06-27-2011, 04:47 PM
  2. Syncing with a new computer
    By Johnarthurson in forum iPad Help
    Last Post: 06-13-2011, 05:05 AM
  3. 2 ipads 1 computer
    By Darryl in forum iPad 2 Forum
    Last Post: 05-24-2011, 07:45 PM
  4. Syncing to new computer
    By galen1 in forum iPad Help
    Last Post: 03-27-2011, 01:15 PM
  5. Syncing two ipads on one computer
    By Jttex752@sbcglobal.net in forum iPad General Discussions
    Last Post: 02-23-2011, 07:54 PM
2 ipads one computer
can i sync 3 ipads to one computer
can two ipads be synched on one computer
can you have two ipads into the same computer
can you sync two ipads to one computer
can you sync two ipads with a computer
how to sync 2 ipads to same computer
sync 2 ipad on one computer
sync two ipads to same pc
syncing two ipads to one computer
syncing two ipads to same computer
two ipads sync in one computer
