Just set up my new iPad 2.
Can't find out how to open CONTACTS.............
This is a discussion on Contacts Help within the iPad Help forums, part of the Apple iPad Discussions category; Just set up my new iPad 2. Can't find out how to open CONTACTS................
New iPad 2 user wants to know how to open CONTACTS..................
You mean that you already see the icon but doesn't open?
Because there is an icon named contacts. Just clic in it
let me know if the problem is when you try to open and it doesn't work
VG(fallaces sunt rerum species)
I think I'm a little confused by this question. You have a Contacts app on the iPad - to open it, just press it.
If you mean to open Contacts from another app, like, say, Mail - while in Mail, open a new message press on either the To or the CC/BCC lines. Then, start typing the name you want to address, their name(s) should appear in a dropdown box. Then you can select the name by just pressing on that. Rinse and repeat for any names you wish.
If I'm way off base in what you need, please clarify? Thanks.
