Results 1 to 3 of 3
    130568
    Dec 2011
    Please tell me that there is a way to get arrow keys on this thing
    And please, don't tell me to use two finger tap and drag. It does *not* work in some forums. Its the most trouble in a forum where the amount of text in a text box is considerably larger than the box itself. Specifically, in at least one forum, if I quote a long post it is effectively impossible to move the cursor to the bottom of the quote where I can start typing my response. Two fingered tap sort of worked....I ended up with a flashing cursor on the web page itself, outside the text box (still not at the bottom of the quote either). Typing would cause the text box to thrash back and forth between the top and near the bottom, which was nearly vertigo inducing
    I need a real solution to this besides the two fingered drag which clearly does not work everywhere.
    13576
    803 times
    Aug 2010
    Western NY state (USA)
    9,444
    I am sorry the two-finger tap 'n' drag does not work for you. I've not experienced it not working for me...
    Well, the only other thing you can do is compose your replies in another app, such as the Notes app. Because, unfortunately, there are no arrows in the default keyboard. There are some keyboards in the App Store that may have arrows - I don't know for sure. But, if there are some, you'll still have to copy/paste as the default keyboard cannot be circumvented.
    Sorry, but that's the way Apple made the keyboard.
    133972
    Dec 2011
    NSW Australia
    Quote Originally Posted by Mickey330 View Post
    But why make it like that? The left .?123 key and the space bar together take up a vast acreage. It would have been very easy to incorporate an inverted T in the design. Here's my suggestion:
    - there's a huge area on the keyboard which isn't used - the dark grey border. Stick the keyboard slide-away key top right on that.
    - slim down all keys by 1mm. Less than this might well have the desired effect.
    - slim down the right hand shift key another mm or so
    - remove the right hand .?123 key altogether
    - eh voilą! The space for an inverted T appears.
    Similar thinking has the left hand .?123 key and the space bar less wide, giving us a Command key and others.
  1. Where's the ARROW keys????
    By Ripplinghurst in forum iPad General Discussions
    Last Post: 12-09-2012, 12:14 AM
  2. Bluetooth Keyboard arrow keys
    By Jay in NYC in forum iPad General Discussions
    Last Post: 07-18-2011, 12:13 PM
  3. Arrow keys
    By Breitling65 in forum iPad 2 Forum
    Last Post: 03-19-2011, 07:47 AM
  4. Replies: 38
    Last Post: 02-06-2011, 08:13 PM
  5. iA Writer adds arrow keys and more
    By ginopiazza49 in forum iPad Apps
    Last Post: 09-23-2010, 01:29 PM
are there arrow keys on the ipad
arrow key on ipad
arrow keys for ipad
arrow keys for ipad 2
arrow keys on ipad
how to use arrow keys on ipad
how to use arrows on ipad
ipad arrow keys
ipad arrow keys app
ipad2 arrow keys
use arrows to scroll on ipad
where are the arrow keys on an ipad
