Results 1 to 5 of 5
    130189
    Nov 2011
    Ipad Does Not Connect to the computer
    I have and Ipad 1, and I got an issue,
    When I connect the ipad to the pc (windows 7) it doesn't connect, not even on DFU mode.
    I tried another Ipad, and it works perfectly, and my Iphone too....
    But when I connect this ipad to another computer, nothing happens too, so the problem is with the Ipad, and it's stuck to the connect to itunes screen.
    So, I wonder, is there a way to force a connection to the ipad so I can restore it?
    emm
    emm is offline
    18534
    4 times
    Oct 2010
    Cal
    161
    Quote Originally Posted by SmashVinny View Post
    If you're getting error code 1611, one solution that has worked is to close and reopen iTunes and then connect your iPad to A DIFFERENT USB slot on the computer. The restore should work then.
    48665
    508 times
    Brisbane, Australia
    19,654
    Hi and welcome to the Forum!
    iPad 2 64gb 3G
    iPad Addict
    95279
    60 times
    Sep 2011
    On a lake in Alabama
    1,324
    Try disabling any anti-virus software/firewall you have running.
    Then re-sync your iPad. You'd be surprised at how many times this has been the issue for some users. !
    iPhone 5 16GB Black (swapping between iOS 7 Beta and stock 6.1.4)
    iPhone 4 16GB CDMA Black (iOS 7 Beta)
    iPad 4th Gen. 32GB Black WiFi only (stock 6.1.3)
    130189
    Nov 2011
    Unfortunatelly, no response... It's not that I'm getting an error or something like that, it simply does not connect.... no signal of connecting, not even the beep sound when we connects a USB device.
    I'm starting to think that the only option is to get to an Apple store and they swipe off the IOS and write it back from the very start.
  1. Replies: 12
    Last Post: 04-09-2013, 06:38 PM
  2. How often you connect your iPad to computer (iTunes)?
    By mobi1 in forum Apple iPad Polls
    Last Post: 02-02-2013, 01:42 PM
  3. Replies: 2
    Last Post: 11-21-2011, 01:13 PM
  4. Replies: 3
    Last Post: 11-17-2011, 11:46 PM
  5. Replies: 7
    Last Post: 05-31-2010, 07:02 AM
ipad 1 does not connect to computer
ipad 1 will not connect to computer
ipad 1 will not connect to pc
ipad does not connect to pc
ipad will not connect to pc
nothing happens when i hook my ipad up to my computer
nothing happens when i plug in my ipad
plug in ipad nothing happens
when i connect my ipad nothing happens
when i plug in ipad nothing happens
when i plug in my ipad nothing happens
when i plug my ipad in nothing happens
