Installing game problem
This is a discussion on Installing game problem within the iPad Help forums, part of the Apple iPad Discussions category; So, I have been playing this game FORCES OF WAR! I was playing earlier today and I had some problem like game speed and customization ...
Results 1 to 2 of 2
    128735
    Nov 2011
    So, I have been playing this game FORCES OF WAR! I was playing earlier today and I had some problem like game speed and customization so I did what I would normally do. I deleted the game from my home screen and I was going back to the app store to download the game again but when it was was downloading my ipad2 glitched and it now says that it is installed on the app store but it's not showing up on my home screen where I keep my games. I need help on how to get this game back on my iPad because this is my favorite game to play on spare time. Please send me some suggestions on what to do to get this app running on my ipad2 again. Thank you all for reading.
    48665
    479 times
    Brisbane, Australia
    19,094
    Quote Originally Posted by ballaholic4_Life
    Hi and welcome to the Forum!
    I also have deleted apps I have downloaded and the app store will remember and say Installed, but I just download it again. I take it that it may be greyed out and you cannot download again? Not sure what you mean there. But anyway give these steps a try and this should fix it for you.
    Do the four finger swipe up or double tap the home button to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. if not a restart is in order.
    When your iPad begins to behave strangely or apps play up these are the first steps you should do to rectify it. If after trying these steps your app is not on the ipad, just download again. Good luck and let us know how it goes!
    We also have our own App - Discussion Forum for IPad Users. It is a very simple app to navigate.
    iPad 2 64gb 3G
  1. EMail Problem after installing OS 5
    By davehays in forum iPad Help
    Last Post: 10-18-2011, 05:42 AM
  2. Problem installing Instapaper into Safari
    By Bob331 in forum iPad Apps
    Last Post: 09-10-2011, 01:05 PM
  3. Problem installing apps
    By Maksumul in forum iPad Apps
    Last Post: 08-26-2011, 11:23 PM
  4. Help! Problem installing sources in cydia!
    By Serianni in forum iPad Hacking
    Last Post: 08-17-2011, 06:47 PM
  5. Problem with installing front glass
    By rakahmn in forum iPad Help
    Last Post: 08-04-2011, 08:37 PM
app store says apps installed but they are not
app store showing game installed when its not
i installed a game on my ipad but it's not showing up on the home screen.
ipad game installed but not showing
ipad game problem installation
ipad game says installed but not
ipad games not installing
my ipad 2 says games are installed but they don't show up where are they
problem downloading game on ipad
problem downloading ipad games
trouble downloading game on ipad
who to contact with a game problem on my ipad
