I am trying to connect my iPad with my iphone 3GS I have turned the bluetooth on, on both devices and is not finding each other.
Am I missing something?
Thank you
This is a discussion on Please help with bluetooth within the iPad Help forums, part of the Apple iPad Discussions category; I am trying to connect my iPad with my iphone 3GS I have turned the bluetooth on, on both devices and is not finding each ...
Thank you
IPad 64GB Wi-Fi + 3G
Thanks for the quick response.
I wouldn't jailbreak my iPad but I would try a app. Would you recomend a app for me to do this?
Thanks again
It depends on what you want to do, the apps just allow you to do what the program is meant to over bluetooth, for instance I've heard that the scrabble game uses bluetooth to allow the iphone to contain your pieces while the game board is on the iPad.
You are fairly limited to what you can do, things such as being able to tether over bluetooth are not possible without both items being jail broken.
If you want to stay within the world of apps, just search for an app that does what you want, maybe add the keyword bluetooth.
I have seen a application called Camera For Ipad and your suppose to connect the iPhone to the iPad and what ever the iPhone views it shows up on the iPad.
That's what I would like to get but wanted to try Bluetooth before installing.
I have wi fi on the iPhone and obviously on iPad I will also look at that app that you mentioned.
