please help with ipad blinking problem and not turning on
This is a discussion on please help with ipad blinking problem and not turning on within the iPad Help forums, part of the Apple iPad Discussions category; I have an iPad 1 that always worked perfectly. the screen is black and then the silver apple logo comes on, then goes away then ...
Results 1 to 3 of 3
    9186
    Jul 2010
    United States
    8
    I have an iPad 1 that always worked perfectly. the screen is black and then the silver apple logo comes on, then goes away then the process repeats. The on and off button at the top seems to be pushed down and won't let me turn the iPad on or off. I am lost without this and so are my grandchildren.
    Thanks in advance
    mhogard
    39716
    12 times
    Santa Barbara, CA
    206
    Make sure your iPad battery has a charge. I let my battery get completely discharged once and had a completely black screen until I plugged it into the charger and it regained some battery power. Freaked me out for a few minutes, but it was fine as soon as it recharged.
    Good luck!
    Never, never, never give up -- Winston Churchill
    Bark less, wag more.
    13576
    748 times
    Aug 2010
    Western NY state (USA)
    9,298
    Try doing a reset of the iPad. Here's the process:
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    If that doesn't solve the problem, I'm afraid that, given your description of a pressed in sleep button, that you'll need to take the iPad to the Apple store for them to look at it. It might be that you have a hardware problem that may be easily fixed by the Apple geniuses.
    Sorry, but that's all the suggestions I can think of.
    Good luck and let us know how you get on.
  1. My iPad isn't turning on
    By VaibhavRohan in forum iPad Help
    Last Post: 10-16-2011, 11:33 PM
  2. preplexed about turning off iPad
    By leypat in forum iPad General Discussions
    Last Post: 06-12-2011, 03:23 AM
  3. ipad not turning on :(
    By Quazie in forum iPad Hacking
    Last Post: 05-30-2011, 04:55 AM
  4. Turning on telephony on iPad 4.2?
    By Cheviot in forum iPad Hacking
    Last Post: 01-04-2011, 03:25 PM
  5. HELP: iPad keeps turning off
    By oe_tuning in forum iPad Help
    Last Post: 10-03-2010, 12:07 PM
apple logo flashes on and off ipad
apple logo keeps flashing on ipad
ipad apple logo comes on and off
ipad apple logo flashing
ipad blinking
ipad blinks off
ipad flashing
ipad flashing apple
ipad flashing apple logo on and off
ipad flashing on and off
ipad keeps flashing apple logo
ipad won't turn on black screen
