I'm wanting to have an entry on a table which is the sum of two columns, but I only want the value to show if it is over zero. If it is less than zero, I want the cell to remain empty. How do I do this? Thanks.
This is a discussion on Numbers help within the iPad Help forums, part of the Apple iPad Discussions category; I'm wanting to have an entry on a table which is the sum of two columns, but I only want the value to show if ...
