Results 1 to 6 of 6
    125896
    Nov 2011
    iTunes refuse to sync music with the iPad 2! NEED HELP!!
    Hello everybody.
    I'm not a new apple user. I've been using an iphone 4 for about more than a year, and therefore I'm very used with the itunes and apple stuffs. All this to make it clear that this probably is not a simple problem, because I have already tryied EVERYTHING. But let's go to the issue:
    I'll try to be short. I've just acquiered my iPad 2, downloaded and intalled de newest iOS 5.0.1 on it, an began syncing it and filling it with my apps, musics, documents etc. But, I don't know why, I'm not able to transfer my musics to the iPad!!!!! I have already tryied to make automattically and manually, but in both ways the same errors occur! Automatically, regardless of how many artists/albums/songs I try to sync, the iTunes always transfer ONLY 3 specific albums! Manually, when I drag the albums over the iPad 2 tittle on the left, all albums are marked with a circle crossed with a bar (symbol indicating that it's not able to transfer), all albums with the only exception the 3 ones that are synced with the automatic setting, wich I can drag and transfer normally.
    PS.: All songs are syncing automattically with my iPhone 4, without any kind of this problems, working well when sync automatically ou manually.
    I've been searching for people with similar problems as mine for a long time and over the internet, but didn't succeed. CAN PLEASE SOMEBODY HELP ME???????
    116 times
    15,249
    I've moved this to the Help section of the Forum, where I think it will receive better attention.
    624 times
    Dayton, WA
    13,312
    This is a long shot, but do you have the Sync only checked songs and video checked on the iPad's Summary page in iTunes, and perchance only the songs in those albums are checked in the music library?
    That's the only (sneaky, easily missed) thing I can think of. At least at the moment.
    125896
    Nov 2011
    Thank you, Tim, I didn't know exactly where were the right place to post it. Twerppoet, yes, it was as required to work, but thank you for the shot!
    Well, after spending almost 2 hours and restoring my iPad 3 times with the apple help support on the phone, the problem was solved (thanks god!!!!!)
    Probably, there are and there will be a lot of people with this problem, because it is not hard to happen (in my opinion), so I'd like to let here my contribution.
    Basically, my friends, the problem was that the music I was trying to sync with the iPad weren't copyed in the iTunes folder, which is a requirement for the iPad, but it's not fot the iPhone to sync. So, first of all, go in "My Computer" (PC mode), go to the "local disk C", "Users", open your user folder, "Music", "iTunes", "iTunes Media" and finally look for the folder "Music". If this folder is empty or if there isn't this folder in this spot, let's go to the next step. Open the iTunes, open "preferences", which I THINK is in the "edit" bar. In preferences, go in advenced and tick the options that indicate that you want to organize things in the iTunes AND the option which says that you wanna copy the musics in the library to the itunes folder (something like this, forgive me, because I am not with the iTunes in front of me right now). Well, now you erase all the musics from you library and put them again, because now iTunes is going to copy to the folder and you will be able to transfer musics to your iPad (at least I was).
    Well, I hope it'll help someone. And, please, forgive my eventuals english errors, I'm from Brazil.
    Bye!
    37823
    538 times
    Cranbrook, Kent, UK
    15,671
    Thanks for the follow up, I'm sure that it will be useful to others with the same problem.
    Your English is fine, probably better than mine.......and I'm English!
    624 times
    Dayton, WA
    13,312
    Wow! I didn't know that. That is just arbitrarily weird; which is a fair description of iTunes, come to think of it. I've always let iTunes copy my music to it's folders, what little I import.
    Thank you for letting us know what happened and how to fix it.
  1. Sync back from iPad to pc music only
    By Paulmontague in forum New Member Introductions - Site Assistance
    Last Post: 11-13-2011, 11:34 PM
  2. Replies: 2
    Last Post: 10-15-2011, 07:37 PM
  3. Replies: 0
    Last Post: 03-09-2011, 06:52 AM
  4. Replies: 17
    Last Post: 02-14-2011, 10:13 AM
  5. Can't sync music from iPhone to iPad using iTunes
    By firmament in forum iPad Help
    Last Post: 09-23-2010, 02:58 PM
can't sync music to ipad
cannot sync music to ipad
cant sync music to ipad
how to sync music to ipad if not working
ipad not syncing music
ipad will not sync anything with itunes
itunes music not syncing ipad
itunes not syncing music to ipad
music does not sync to ipad
music not sync to ipad
music not syncing to ipad
music not syncing to ipad 2
