How to clear the Diagnostics & Usage Data
This is a discussion on How to clear the Diagnostics & Usage Data within the iPad Help forums, part of the Apple iPad Discussions category; Somebody please advise me how to clear the Diagnostics & Usage Data for ipad2 in General -> About -> Diagnostics & Usage -> Diagnostics & ...
Results 1 to 10 of 15
    14191
    Sep 2010
    Singapore
    9
    Somebody please advise me how to clear the Diagnostics & Usage Data for ipad2 in General -> About -> Diagnostics & Usage -> Diagnostics & Usage Data.
    Thanks in advance
    116 times
    15,249
    I've moved this to the Help section, where I think it might receive better attention.
    48077
    10 times
    Illinois
    488
    This looks like it may be an iOS5 function. I don't have it on my non-updated iPad2, but it's on my iPhone 4s. From what I've read you can't delete the entries directly but some claim they're deleted when you sync to iTunes. Others say they don't. On my phone at least you can opt to not send the diagnostic data to Apple. Some claim doing this improves battery life. I'm going to try turning it off and see if it helps on battery drain or if they flush out on their own or the next time I sync. Not sure this helps you but I'm glad you asked if it ends up helping with battery life on my phone.
    126390
    Nov 2011
    5
    I have over 200 diagnostics built up, mostly low memory warnings, and I'd like to be rid of them. Some of the reports in themselves run to several pages of data, and I can't afford to have these diagnostics hanging around, consuming my "hard disk". ( I do love Aweditorium, but it's a real disk chewer.)
    I asked at my local "Genius" Bar, and was told there is no way to delete these diagnostics, other than a full factory reset, and I'm not brave enough to try that. Seems a very drastic action to have to take to remove these reports. I have the Don't Send option ticked, by the way.
    If I've understood the chronology correctly, Diagnostics and Usage was an "improvement" introduced in 5.0. Hopefully a future upgrade will introduce a further improvement to delete or disable diagnostics.
    The low memory problem seems to be primarily due to Safari, again something introduced by iOS 5? The cure for low memory, I was told at the Bar, is to jiggle-close Apps frequently, but I've had the problem with just three Apps open, one of them being Safari. So not poor user maintenance I think (besides, I thought there was no need for user maintenance on Apple devices) but a problem with 5.0 - either iOS should sort out low memory itself without a diagnostic report, or Safari should not be gobbling up so much RAM.
    How do we get Apple to address issues like this in future versions?
    37823
    482 times
    Cranbrook, Kent, UK
    15,289
    Quote Originally Posted by jjon99
    You can leave feedback here http://www.apple.com/feedback/ipad.html
    BTW, I'm not sure where you heard that Apple devices don't require user maintenance, all computers of all makes benefit from a bit of spring cleaning.
    20755
    7 times
    Nov 2010
    Michigan
    436
    I haven't paid much attention to this, but it seems that with "don't send" ticked, the logs accumulate for ever. With "automatically send" selected, the logs appear to clean out as they are "collected".
    "that's how they get ya!"
    iPad Wizard
    49745
    370 times
    6,601
    If you don't send, it collects for about a month, from my experience. It auto-deletes older ones.
    126390
    Nov 2011
    5
    Thanks, I'll try allowing the data to be sent to see if that clears them. With location services turned off, so they don't get everything.
    I notice under "About Diagnostics and Privacy" they say:
    "You may also choose to turn off Diagnostics altogether. To do so, open Settings, tap General, tap About and choose Don’t Send under Diagnostics & Usage. "
    This seems not to turn off Diagnostics altogether, but rather just to turn off the sending of Diagnostics, as I've been running without sending and can vouch for the fact that Diagnostics still accumulate.
    I assume the sending happens sometime overnight. Was the option not to send the battery improvement feature introduced in 5.1?
    20755
    7 times
    Nov 2010
    Michigan
    436
    It's possible, I haven't had any real battery issues, but there's no doubt that "not sending stuff" will save some battery. How much, is any ones guess.
    iPad Wizard
    49745
    370 times
    6,601
    I doubt it's a battery feature. I think it's a privacy issue.
  1. Button to clear spreadhseet data
    By SpeedyRocketeer in forum iWork Forum
    Last Post: 09-08-2011, 08:47 PM
  2. 3G data usage?
    By HughB in forum iPad 2 Forum
    Last Post: 08-20-2011, 05:41 PM
  3. data usage
    By ercsliberty in forum iPad 2 Forum
    Last Post: 05-24-2011, 01:04 AM
  4. Data Usage
    By 60DegreeVVT in forum iPad Carriers
    Last Post: 06-09-2010, 01:21 AM
  5. Data usage
    By FirstApple in forum iPad Carriers
    Last Post: 06-07-2010, 06:34 AM
clear diagnostic data iphone
clear diagnostics and usage data
clear diagnostics and usage data iphone
clear iphone diagnostic data
delete diagnostic and usage data iphone
delete diagnostics and usage data iphone
how to clear diagnostic data from iphone
how to clear diagnostics and usage data
how to delete diagnostic and usage data from iphone
how to delete diagnostic data from iphone
how to delete iphone diagnostic data
ipad clear diagnostic data
