iPad 2 not connecting to WiFi properly.
This is a discussion on iPad 2 not connecting to WiFi properly. within the iPad Help forums, part of the Apple iPad Discussions category; So I recently updated to iOS 5.0.1 OTA. Since then, WiFi on my iPad doesn't even connect properly. It shows the signal bars on the ...
Results 1 to 7 of 7
    83480
    2 times
    Jul 2011
    198
    Unhappy iPad 2 not connecting to WiFi properly.
    So I recently updated to iOS 5.0.1 OTA. Since then, WiFi on my iPad doesn't even connect properly. It shows the signal bars on the Status Bar (all three bars full) but I can't access the internet at all. When I check the IP address, it shows random numbers, but I know that a normal working IP address is usually 192.168.1.x.
    I've already tried a reboot, two restores. The next thing I did was unplug my router and modem, then replug them, but that isn't helping either. I have no idea what to do next. Can someone help me before I pay a couple bucks for Comcast to come over and "fix" it? Thanks guys.
    Peacemaker.
    They say a car represents your personality. I have no car.
    116 times
    15,249
    One solution that has worked for some Members is to tell the iPad to 'Forget the connection'
    So, 'Settings', 'WiFi' then press the blue arrow to the right of the WiFi connection. This takes you through to a more detailed settings screen. First of all, ensure that DHCP is checked and that the proxy connection is off. If either of those are not correct then see if that fixes the problem.
    But assuming that's not the issue then - towards the top of the settings box there's a 'Forget this connection' box. Tell the iPad to forget the connection.
    Now return to the 'Settings', 'WiFi' screen and wait for the iPad to 'find' your WiFi and re-enter any passwords and/or encryption details that it needs.
    See if this fixes the problem but, if it doesn't, come back and we'll think of some more ideas.....
    Good Luck
    83480
    2 times
    Jul 2011
    198
    Already tried it. :/
    Never mind. It's time to call Comcast.
    116392
    Oct 2011
    Davao City, Philippines
    Experienced the same problem. Is there any way to revert back to the old OS? I tried doing what was shared but still, I could not connect to any WiFi network...
    165479
    Feb 2012
    Washington DC
    I am also having a problem connecting. I have an Ipad2 with 3GCellular Data and it's not connecting to anything! It just started this today so I'm not sure what the issue is. Please assist!
    56481
    5 times
    May 2011
    185
    I had similar problems until I upgraded my router and assigned a static ip address.
    165479
    Feb 2012
    Washington DC
    Quote Originally Posted by drb_52
    How do I do that?
  1. Replies: 6
    Last Post: 12-14-2012, 08:49 AM
  2. Connecting to wifi...need help!
    By LynnM in forum iPad Help
    Last Post: 06-16-2011, 08:56 PM
  3. iPad 2 WiFi not connecting
    By superbaba808 in forum iPad Help
    Last Post: 05-09-2011, 01:05 AM
  4. Connecting to work wifi
    By ragdollmomof2 in forum iPad Help
    Last Post: 03-05-2011, 07:58 PM
  5. connecting ipad to cellphone for wifi?
    By MsAmandaLove in forum iPad General Discussions
    Last Post: 01-28-2011, 01:40 PM
ipad 1 wifi not working comcast wifi
ipad 2 not connecting to wifi
ipad 2 wifi not connecting
ipad cannot connect to wi fi properly
ipad doesn't connect to wifi
ipad doesn't want to connect to wifi
ipad shows ip address but doesnt connect
my ipad doesn't connect to wifi
why doesn't my ipad connect to wifi
why isn't my ipad connecting to wifi
why isn't the wifi working on my ipad
wifi not connecting on ipad 2
