Help....old computer died
This is a discussion on Help....old computer died within the iPad Help forums, part of the Apple iPad Discussions category; Hey guys my old computer just died. I can't get it to boot up. So I can't access all my stuff for my ipad2. I ...
Results 1 to 3 of 3
    76994
    Jul 2011
    18
    I guess I will be using my wife's computer. We both have ipad2's, but with different iTunes accounts. Can someone please tell me how to set up iTunes so that we can share the same computer withount my pad getting all her doctor crap and her iPad getting all of my us history stuff.
    Also what do I do about not being able to access my stuff from iTunes on my old computer? Any suggestions?
    Nate
    53991
    2 times
    May 2011
    Maryland
    180
    Not positive about two iPads on one iTunes account, at least not a pain-free and not time-consuming way. As for the dead computer, you can pull the hard drive and put it in an enclosure and use it as an external. If the computer is a desk top, it will be pretty easy. If a laptop, a bit more difficult. You should then be able to transfer your iTunes stuff to your wife's computer. If the wife's computer is a Mac it should read any file on the drive. I had a laptop die. Pulled the hard drive and was able to get all my wife's photos off and onto hey iMac.
    1522 times
    Walla Walla, WA
    15,429
    The easiest way to set up two iPads with different accounts on the same computer is to set up two login's for the computer; one for here and one for you. This will keep the two iTunes libraries separate.
    To connect your iPad to the new computer, and avoid losing stuff you already have on it, follow the instructions I'll tack onto the bottom of the post.
    Getting anything that is still on the old computer, but not on the iPad can be tricky. It depends on whether the hard drive can be accessed. You would be best off taking it to someone local who can try and recover your data. Once they do, you can try importing it into iTunes again.
    For most of the stuff you've purchased from iTunes, you only need to visit the Purchased section in the iTunes Store and re-download it. Music, most TV shows, iBooks, and Apps can all be recovered this way. Movies and music videos can not.
    Good Luck.
    Here is Apple's recommendations on how to transfer all your stuff to a new iPhone. With a few modifications it works very well for moving your iPad to a new computer. Wish I could find one as well written for the actual task.
    How to back up your data and set up as a new device
    Start by going into iTunes Preferences (before connecting the iPad) and turning off auto-sync. It is under the Devices tab. This will prevent any unwanted syncing before you are ready.
    Do only the parts that apply to your information/situation (i.e.; if you are syncing contacts with Google, don't do the Personal Information Manager part. Stop when you get to the Restore step.
    It would be wise, after the Transfer Purchases option to go through iTunes and make sure everything (media, app, book) got transferred. If not you may have a few more steps to insure all your stuff gets safely backed up on the computer.
    NOTE: If you have picture albums in the Photos app, and they are not backed up somewhere other than the iPad, you need to save them first before doing anything else. The first sync will remove them. The PhotoSync app works well for this, and you can use it before starting any of the other procedures.
    The quality of the pictures recovered this way will probably not match the originals. iTunes optimizes photos for viewing on the iPad when it syncs them.
  1. Laptop has died, can I unsync?
    By Lorelie in forum New Member Introductions - Site Assistance
    Last Post: 10-03-2011, 11:57 PM
  2. My iPad 2 has already died!!!
    By Wicked x Josh in forum iPad General Discussions
    Last Post: 03-13-2011, 04:42 PM
  3. So my iPad died...
    By newfmp3 in forum iPad General Discussions
    Last Post: 02-22-2011, 11:57 AM
  4. iPad died unexpectedly
    By sh75225 in forum Off-Topic
    Last Post: 08-29-2010, 02:11 PM
  5. Need help!!! Ipad 3g 64gb died!!!
    By trev2401 in forum iPad General Discussions
    Last Post: 05-31-2010, 10:00 PM
how to transfer itunes library when old computer dies
itunes library on dead computer
itunes old computer died pulled hard drive
my computer died and i lost my itunes
my computer died so how do i upgrade my ipad
my laptop dead. how to transfer photo from ipad to pc
pc died ipad
the computer i sync ipad 1 with died
