Spelling replacement words
This is a discussion on Spelling replacement words within the iPad Help forums, part of the Apple iPad Discussions category; Hello, I have a huge issue on this iPad respelling words. For some reason when it replaces a word it removes just 1 letter from ...
Results 1 to 8 of 8
    122861
    Nov 2011
    Southeastern Wisconsin
    11
    Hello, I have a huge issue on this iPad respelling words. For some reason when it replaces a word it removes just 1 letter from the spelling and makes up a word that does not exist, for example my name... It corrects my last name from Clemmer to "Clemm r" ??? That is just a single example. What would cause that? And some words that I use all the time that it recognizes as spelling errors are not, how can I get the iPad to "learn" the words? Thanks a ton guys... Mjc...
    37823
    479 times
    Cranbrook, Kent, UK
    15,261
    It will eventually remember the correct spelling however, it has been reported many times that if you add a word to the Contacts app then the iPad will not autocorrect it when you use it in future.
    iPF Expert
    33508
    108 times
    Feb 2011
    Somerset-UK
    7,873
    I use the shortcuts in settings - general - keyboard - shortcuts. Any words you use frequently will be accepted. I have even put my email addresses in there. You just need two letters or more to remember to activate the shortcuts command. It's great. I know of people who have 200 activated.
    IPad 3 32GB wifi, 2x iphone 4, iPhone 3GS 32GB , ipad 1 32GB ,2x iPod touch 2G, BT keyboard
    All for One and One for All!!!
    From Somerset UK
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    I this persist, try going to Settings > General > Reset > Reset Keyboard Dictionary. Otherwise, Try a reset. Close all apps then - Hold down the HOME, bottom button, and the SLEEP, top button, for about 10 seconds until the Apple icon appears, then release buttons. Allow it to reboot, it may take a few minutes, don't panic like I did, wait for it to reboot. Cures many weird problems on iOS devices.
    Good Luck
    Pocobear
    122861
    Nov 2011
    11
    Quote Originally Posted by Hayles66
    I
    L have to give this a shot as well, sounds great.. Thanks Mjc...
    122861
    Nov 2011
    11
    [QUOTE="Gabriel1"]It will eventually remember the correct spelling however, it has been reported many times that if you add a word to the Contacts app then the iPad will not autocorrect it when you use it in future.
    The Archangel[/QUOT]
    Where do you add words to the contacts app? To do this.... Hmmmm thanks Mjc...
    Like my Mjc, it shows it's spelled wrong and tries to replace it, adding it to the contact apps will prevent this? Ty... Mjc
    37823
    479 times
    Cranbrook, Kent, UK
    15,261
    Just open your Contacts App and make a new contact......it should work just fine (not that I've ever done it though!).
    iPad Wizard
    49745
    370 times
    6,598
    Maybe you could create a keyboard shortcut for whatever you're trying to spell regularly.
  1. Spelling Auto-correct Question
    By Munky in forum iPad OS
    Last Post: 10-09-2012, 02:20 AM
  2. Need app for school spelling words
    By sdelsip in forum iPad Apps
    Last Post: 10-17-2011, 07:55 AM
  3. Check spelling / auto correction?
    By sjleworthy in forum iPad Help
    Last Post: 06-20-2011, 05:46 AM
  4. Spelling Checker - Auto Correction
    By RAC in forum iPad General Discussions
    Last Post: 05-16-2011, 05:32 PM
  5. Words with Letters for Words with Friends
    By SparkleApps in forum iPad App Announcements
    Last Post: 04-28-2011, 01:57 PM
email recieved name spelled wrong when sent from ipad
how to replace wrong spelling
ipad correct wrong spell
ipad help word replacement
ipad spelling correction
ipad word replacement
iphone spelling my name wrong on emails
remove a spelling word on a ipad
sending email from ipad spell wrong
speeling replacement
spelling replacement
spelling word to replace
