Wifi connection to my ipad2 is getting slower and slower
This is a discussion on Wifi connection to my ipad2 is getting slower and slower within the iPad Help forums, part of the Apple iPad Discussions category; My wifi connection to my ipad2 is getting slower and slower, and is becoming more noticeable when connecting to the apps store . Co uld ...
Results 1 to 2 of 2
    112745
    Oct 2011
    20
    My wifi connection to my ipad2 is getting slower and slower, and is becoming more noticeable when connecting to the apps store. Could it be something to do with the cache or memory? I have tried resetting my wifi connection but it makes no difference. Is there a setting that will clear all cache and memory? Thank you in anticipation.
    iPF Super Guru
    40746
    99 times
    NW Left Coast
    3,504
    Several things often help improve the performance and WiFi connections on the iPad. Simply shutting down apps and restarting the iPad can fix most issues.
    Quit Apps: To quit an app double press the Home button and the Multitasking Tray will appear at the bottom of the screen revealing all of the open apps. Tap and hold any app icon until all of the icons start jiggling. A red circle with a "-" (minus sign) will appear in the upper left-hand corner of each icon. Tap the red circle and the app will close.
    If that doesn't do it, try restarting the iPad and if that still doesn't do it try resetting it.
    Restart the iPad: Press and hold down the Home button on the front of the iPad for few seconds until the red slider appears, slide this across to shut the iPad down. Restart the iPad by pressing the power button on the top until the Apple logo appears.
    Reset the iPad: You can do this by pressing the Home button and the Sleep/wake button on the top the iPad's case and holding them down together for at least 10 seconds, until you see the Apple logo. The iPad should then reset itself. The boot up process takes a few minutes and then the iPad should be responsive again.
    More here:
    iPhone, iPad, iPod touch: Turning off and on (restarting) and resetting
    Distance from the Wi-Fi router can impact the signal as well as interference from other electronics including microwaves, wireless home phones, cell phones, etc. Walls and floors with metallic studs can have a negative impact on Wi-Fi signals as well. Sometimes moving the Wi-Fi modem/router closer to where you use the iPad most can help.
    Another tip is to reboot your network and everything on it including your modem, router, etc. while your iPad is off. Turn your iPad back on and see if the connection has improved.
    Lastly you can try deleting the network connection on your iPad and then go back and set it up again. Settings > Wi-Fi > tap on your network > Forget this Network. It sounds like you may have already tried that though.
    Here's some more info if none of that works...
    Checklist for troubleshooting Wi-Fi connection problems.
    iOS: Troubleshooting Wi-Fi networks and connections
    Slowing of i-pad2
    Hope that helps...others may have some additional ideas.
    Let us know how it goes!
  1. iPad slower after ios5?
    By Sonicrobby in forum iPad 1 Forum
    Last Post: 11-15-2011, 04:00 PM
  2. WiFi in hotels - why it's getting slower....
    By Tim SPRACKLEN in forum User News Submissions
    Last Post: 10-31-2011, 02:43 AM
  3. Replies: 3
    Last Post: 06-04-2011, 08:16 AM
  4. Ipad 2 is slower to recharge and lower battery power than ipad 1
    By felixslm in forum iPad General Discussions
    Last Post: 05-27-2011, 11:22 PM
  5. IPAD Wifi slower than dialup
    By 1298767 in forum iPad Help
    Last Post: 01-27-2011, 03:16 AM
ipad 2 slow internet connection
ipad 2 slow wifi
ipad 2 wifi slow
ipad is getting slow
ipad slow internet connection
ipad slow wireless connection
my ipad wifi is slow
slow internet connection on ipad
