Screen on while charging?
This is a discussion on Screen on while charging? within the iPad Help forums, part of the Apple iPad Discussions category; Is there a config option or setting anywhere that would let the screen stay on while it's charging? Or an app? I have the iPad ...
Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By Mickey330
  • 1 Post By Gabriel1
Thread: Screen on while charging?
    65490
    2 times
    Jun 2011
    Canada
    83
    Question Screen on while charging?
    I have the iPad 2! It's NOT JB.
    Thanks for any help.
    "A cucumber should be well sliced, and dressed with pepper and vinegar, and then thrown out, as good for nothing."
    Dr Samuel Johnson (1709-84)
    13576
    1447 times
    Aug 2010
    Western NY state (USA)
    11,055
    In the Settings app, under the General tab, there's a line on the right side titled "Auto-lock."
    If you press it, you will be offered different times for which the iPad will wait to turn off the screen, one of which is never. Selecting Never will ensure your s teen does not shut off.
    One piece of advice, though. Don't keep it set to Never all the time so you can save battery life...
    Hope this helps.
    tristaned likes this.
    65490
    2 times
    Jun 2011
    Canada
    83
    Quote Originally Posted by Mickey330 View Post
    Hope this helps.
    Thanks for your reply.
    Yes, I was aware of the Auto-lock settings, but I was looking for an additional setting that controls what it will do while charging. I've seen this offered on other PDAs, laptops, and net books I've owned and used in the past. I'm looking for someway, without JB, to do this on my iPad.
    I'm guessing from your reply that I'm going to be out of luck with this.
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    There should be no difference with what Marilyn told you regardless of whether you are charging or not. If there is, let us know the symptoms and we'll do our best to help.
    65490
    2 times
    Jun 2011
    Canada
    83
    Quote Originally Posted by Gabriel1 View Post
    But that's kind of the point, I want there to be a difference whether I'm charging or not.
    I definitely want to have an auto-screen-off when it's running off the battery, but I do NOT want an auto-screen-off when it's plugged in and charging. That way when I pop it into a stand beside my bed at night I can have a clock/alarm app running, set fairly dim that I can see during the night.
    All my previous PDAs, both Palms and HP iPAQs, had this "while plugged in" setting. Also all Windows laptops and net books have different screen options available depending on whether they're running off power or battery. If the iOS iDevices don't have this option it's a multi-year backwards step, albeit a small backwards step.
  1. Usb charging
    By owenmorris in forum iPad 2 Forum
    Last Post: 04-01-2011, 12:12 AM
  2. Replies: 7
  3. Charging on the Go.
    By MuchoiPad in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-21-2011, 12:12 AM
  4. Charging
    By Hawkmech in forum iPad General Discussions
    Last Post: 08-12-2010, 09:54 AM
  5. Charging???
    By HarlyFan in forum iPad Help
    Last Post: 07-12-2010, 08:51 AM
how do i make it to where my iphone 4s screen stays on whil charging
how to make ipad screen stay on
ipad screen stay on
ipad screen stay on when charging
ipad screen stays on all the time
iphone screen stay on while charging
iphone stay on while charging
make iphone stay on when plugged in
