Short Battery Life
This is a discussion on Short Battery Life within the iPad Help forums, part of the Apple iPad Discussions category; I just got my IPAD2 a few days ago concerned my battery only lasts a few hours thought it was supposed to last for ten ...
Results 1 to 4 of 4
    110022
    Oct 2011
    USA
    28
    Short Battery Life
    I just got my IPAD2 a few days ago concerned my battery only lasts a few hours thought it was supposed to last for ten hours. Is my new IPAD2 defective???
    102366
    6 times
    Sep 2011
    Edinburgh
    58
    iPad 2 review -- Engadget
    Engadget's benchtest tells you all you need to know, if you are only getting a couple of hours, then yes, something is wrong! A Google search brings up many benchtest results showing good battery life.
    Welcome to the forum - I doubt you are getting the best from your new gadge so go see a Genius. I would post further questions in the forums though if it was me.
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by luvbugipad2 View Post
    Although the iPad's battery life is certainly amazing (often 9 hours or more), how long it will last depends on a combination of some settings and how it's being used.
    The biggest energy glutton is screen brightness. Moving the brightness from 100% to 75% or less can make a very big impact on battery life. Watching movies, GPS and other high-demand CPU activity can take a toll as well. Here's more information that might be helpful:
    Optimize Your iPad Battery Settings
    You might also try resetting (not restarting) your iPad. That can often smooth things out in a number of areas. (It's not needed on a regular basis mind you, only when things aren't working properly).
    • Reset the iPad: You can do this by pressing the Home button and the Sleep/wake button on the top the iPad's case and holding them down together for at least 10 seconds, until you see the Apple logo. The iPad should then reset itself. The boot up process takes a few minutes and then the iPad should be responsive again. More here:
    iPhone, iPad, iPod touch: Turning off and on (restarting) and resetting
    FWIW I can usually get 7 to 9 hours or more on my iPad in mixed daily use. My brightness level is usually set at about 60% which works very well for me inside....higher outside of course.
    That said, if you've charged your iPad to 100% and it only lasts a few hours doing anything, then yes, that's not normal and you should contact Apple, either by visiting a local Apple store or...
    Apple - Support - iPad - Contact Support
    Apple - Support - Contact Support
    Contacting Apple for support and service
    BTW, I'm going to give your question its own thread so that others can respond/benefit.
    Hope that helps and let us know how it goes!
    90362
    28 times
    Aug 2011
    Milwaukee, WI
    960
    See, when I put my iPad's brightness to anything higher than 33%, the battery drains like crazy. But if I keep it that low, it lasts the normal 9-10 hours.
    Lindsey
    Black 16GB iPad 2 | Jailbroken via Absinthe
    White 16GB iPhone 4S | Jailbroken via Absinthe
  1. Battery life
    By daquilino in forum iPad General Discussions
    Last Post: 07-22-2011, 06:28 PM
  2. battery life
    By kenrainford in forum iPad Help
    Last Post: 07-04-2011, 12:58 AM
  3. Battery Life?
    By Heaviside in forum iPad Help
    Last Post: 12-18-2010, 01:27 PM
  4. 3G Battery Life
    By msskarina in forum iPad General Discussions
    Last Post: 05-02-2010, 08:12 AM
ipad 2 low battery life
ipad 2 short battery life
ipad battery life is short
ipad battery life short
ipad battery short life
ipad low battery life
ipad short battery life
low ipad battery life
short battery life ipad
short battery life on ipad
shortened ipad 2 battery life
why ipad battery life short
