How to Remove previous and next on top of keyboard
This is a discussion on How to Remove previous and next on top of keyboard within the iPad Help forums, part of the Apple iPad Discussions category; How to Remove previous and next on top of keyboard...
Are you talking about the on-screen keyboard? I don't see this on my on-screen keyboard. I only see this when I'm filling in a form in Safari, as it enables me to move from text box to text box....
Yes when I try to compose a message I see that previous and next on top of the iPad keyboard,these were not there till yesterday looks I must have presses some settings,how could I remove them
Further to my first post there are several websites while using the safari I can't copy nor cut but when I use opera I can do the same your help in above matters would good
Yeah read your message I am well practiced for copying and pasting but as said its just clear now that on few websites after copying the selected thing becomes blue and copy sign comes up when I click on copy and try pasting the same there is nothing which gets pasted
In fact the old stuff which is copied from other websites gets pasted but not the one which I had copied
What app are you trying to paste the copied material into?
It's a text message which I am trying to copy from my company website,that does not get copied.Originally Posted by Tim SPRACKLEN
To my other question you see now when I am composing this message here now I don't ser the previous and next buttons above my keyboard but when I compose the same in safari I see those buttons
That's part of the HTML code used in your company's website. Have they protected the content - i.e. made it impossible to copy and paste?
Will just check on that by the way how to remove the previous and next tabs above the keyboard
But the other point is I can copy and paste by using opera browser so why not safari
Have you got your Opera browser set as a mobile browser or have you configured it to look like Internet Explorer or a similar desktop browser?
