Mp4 won't go into iTunes
This is a discussion on Mp4 won't go into iTunes within the iPad Help forums, part of the Apple iPad Discussions category; I have several movies in mp4 format that I put into iTunes to sync to my iPad. I have one movie that will not go ...
Results 1 to 4 of 4
    94252
    Sep 2011
    Greensboro, NC
    37
    I have several movies in mp4 format that I put into iTunes to sync to my iPad. I have one movie that will not go in. The file is not corrupt because it plays perfectly through windows media player, but I cannot get it into iTunes. Suggestions?
    10230
    4 times
    Jul 2010
    96
    It has to be in a .m4v format. Use Handbrake to convert it.
    94252
    Sep 2011
    Greensboro, NC
    37
    Not true. All of my movies in iTunes are mp4.
    iPF Super Guru
    40746
    99 times
    NW Left Coast
    3,504
    It's true that most .mp4 files will play on the iPad but some have copy protection that prevents it. As Todd M suggested, converting the video that's being uncooperative is probably your best bet. Handbrake is an excellent, free program that can probably take care of it and .m4v is a good choice.
    That said I had a similar file that wouldn't work and ended up simply changing the file type from .mp4 to .m4v and it worked. I've no idea if that would do it in this case, but it's worth a try...you can always change it back.
    FWIW, these are the files that the iPad generally supports:
    H.264 video up to 1080p, 30 frames per second, High Profile level 4.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format. Source: http://www.apple.com/ipad/specs/
    Best of luck and let us know how it goes!
  1. Replies: 2
    Last Post: 04-26-2011, 06:38 AM
  2. In iTunes under devices i select iPad then audio and iTunes crashes
    By emmett in forum New Member Introductions - Site Assistance
    Last Post: 04-25-2011, 07:16 PM
  3. iPad vs iTunes on Windows and iTunes on Apple
    By lionman in forum iPad General Discussions
    Last Post: 11-21-2010, 02:57 PM
  4. Replies: 11
    Last Post: 09-23-2010, 06:29 PM
  5. Replies: 0
    Last Post: 06-18-2010, 09:31 PM
.mp4 won't play in itunes
movies wont go into itunes
mp4 file won't go into itunes
mp4 wont go into itunes
videos wont go into itunes
why won't my mv4 file go into itunes
why wont my mp4 videos go into itunes
