Really, need your help! An unknow id appears when updating apps
This is a discussion on Really, need your help! An unknow id appears when updating apps within the iPad Help forums, part of the Apple iPad Discussions category; I have an IPad 2. just got the new ios5 with no problems. I am trying to update some apps, but an apple id pops ...
Results 1 to 8 of 8
    115494
    Oct 2011
    8
    I am trying to update some apps, but an apple id pops up ( maybe was an older one, but I got no email adress related to it) so when I enter my usual password there seems to be a missmatch!
    could anyone help me to get rid of this 'old' id and be able to update my apps!
    i searched many places, asked a lot of people, searched here ( honest!), but can't get my iPad to work as before the iOS upgrade. No jailbreak in my iPad.
    Regards,
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,274
    In your Settings app, on the left side, scroll down until you see the "Store" line; press it. On the right side, at the bottom, you should see the Apple ID currently associated with that iPad.
    If it is different than the one you want, press it and select "Sign Out." Then, you should be offered the opportunity to re-sign back in. This time, sign in with the Apple ID you want to use (that matches your current password).
    That should do it. Please let us know how you get on.
    115494
    Oct 2011
    8
    Quote Originally Posted by Mickey330
    Marylin, thanks for your reply. Indeed, right where you say there's my 'real' Apple ID ( for which I know the password). The problem is that when I am going to update the apps in the Store, when I prompt my iPad to do so I am asked for a password ( as usual) but there is where appears a different Apple ID!. Now, that's the problem as I can't remember any passwoed related to that ID. I hope I made myself clear.
    Thanks in advance.
    77545
    Jul 2011
    12
    Did you buy the iPad used? If the app downloaded is associated with the old owner it will not upgrade unless you know the password from the previous owner. You may need to delete the app and download it with you apple ID.
    iPad Ninja
    62473
    62 times
    Jun 2011
    1,607
    If you have a second ID you do not remember the password for, you can log into iTunes and use the Forgot my Password option.
    If you still cannot remember it, you will have to delete the apps that are trying to update themselves based on that iTunes account. There is no other way to disable those update messages or password requests.
    115494
    Oct 2011
    8
    Actually, the iPad belongs to my dad. Bought brand new. I convinced him to upgrade to iOS 5 - why shouldn't I? And now he can't get the upgrades. I'm in trouble now ! he can't get updates, email is not send messages correctly, lots of apps he bought are missing, he's not happy!, that's why I' crying for help.
    Delete upgrade-asking apps? - that's suicide! Suggestions, please!
    77545
    Jul 2011
    12
    If it belongs to your dad then you should be able to delete the app anyway and reload it. I would go to iTunes and hit forgot password just to be sure password is correct.
    As for email not sending you need to make sure the password in the settings for outgoing mail is set. For some reason when I upgraded all my passwords in mail had to be reset.
    115494
    Oct 2011
    8
    Quote Originally Posted by magicbytim
    Hi all:
    It took me a couple of minutes to realize the logic behind your suggestion, but it worked !
    Thank you so much for all your kind replies and suggestions. My dad's iPad is now back to normal. Great advice, more than perfect timing!
    Best regards,
    Andres
  1. Apps not updating
    By mlsen in forum iPad Apps
    Last Post: 08-22-2011, 10:59 PM
  2. ? on apps updating
    By ntrddragn in forum iPad Hacking
    Last Post: 05-20-2011, 12:43 PM
  3. Updating Apps
    By Drummo in forum iPad Help
    Last Post: 03-11-2011, 02:02 AM
  4. Apps Updating
    By Biggysmallz in forum iPad General Discussions
    Last Post: 02-22-2011, 07:46 AM
  5. Updating apps
    By Munchkin52 in forum iPad Help
    Last Post: 02-21-2011, 12:44 AM
( why does my old apple id keep popping up)
app store states an app needs updating, but the app is associated with an unknown apple id
apple id keeps popping up on my ipad
apple id password keeps popping up
cant get rid of apple id password pop up
how to get rid of a unknown apple id from ipad 2
how to get rid of apple id on ipad
ipad asks for unknown apple id password
my old apple id keeps popping up
old apple id keeps coming up
try to update apps on ipad but another apple id is popping up
when i upgrade apps another apple id appears
