How to load and view PDF on Ipad?
This is a discussion on How to load and view PDF on Ipad? within the iPad Help forums, part of the Apple iPad Discussions category; I have installed PDF viewer on the Ipad. I have a ton of books on my PC in PDF format. How can I load these ...
Results 1 to 6 of 6
    6741
    Jun 2010
    14
    I have installed PDF viewer on the Ipad. I have a ton of books on my PC in PDF format. How can I load these onto my Ipad?
    Thanks.
  2. #2
    iPad Ninja
    3495
    4 times
    May 2010
    Switzerland
    2,024
    1) Connect the iPad to iTunes
    2) click on your iPad and then Apps inside the iPad
    3) Scroll down
    4) Here you will see the app that you installed to handle PDF files
    5) Click on that app and you will see an area to the right where you may drag and drop files
    The best part is that to do this, you don't have to be connected to your iTunes, any computer with iTunes will do.
  3. #3
    6741
    Jun 2010
    14
    Thank you!
    It's all done in Itunes under the Ipad/Apps.
    I found it.
    Thank you for your quick response!
  4. #4
    iPad Master!
    1474
    Mar 2010
    Marietta, GA - USA
    740
    Post GoodReader Wins All iPad PDF Viewer Showdowns
    Quote Originally Posted by Pvanosta View Post
    Thanks.
    You should have bought GoodReader for $0.99.
    Out of the box it is hands down the best PDF viewer and file manager for the whole iPad you can buy.
    IMHO GoodReader should be on EVERY IPAD.
    The more truly powerful apps like this that you put on your iPad the better the experience will be.
    GoodReader supports just about every conceivable way of getting files onto the iPad, including DropBox. Read the help files before using it.
  5. #5
    iPad Ninja
    5175
    May 2010
    2,059
    +1 for Goodreader...and you can import them through iTunes as well as organize them into folders.
  6. #6
    3528
    May 2010
    Orange County, CA
    194
    +1 for GoodReader. At $0.99 it really does a great job at organizing all the documents (PDF or otherwise). The latest release from Friday (v2.8) includes many performance improvements and even horizontal page turning (like iBooks).
    Piko
Sponsors
  1. Unable to view Apple WWDC 2010 keynote address on ipad
    By Fotonutz in forum iPad General Discussions
    Last Post: 06-08-2011, 04:28 AM
  2. How can I view wmv files in emails?
    By mknoebel in forum iPad General Discussions
    Last Post: 03-25-2011, 06:09 AM
  3. How can I load my DVD movies on to the iPad?
    By JLStrange in forum iPad General Discussions
    Last Post: 08-23-2010, 09:22 PM
  4. Why is it so hard to get my AVI video to load on iPad?
    By wacnstac in forum iPad General Discussions
    Last Post: 06-08-2010, 10:42 AM
  5. View Network Files?
    By eflyersteve in forum iPad General Discussions
    Last Post: 04-27-2010, 10:27 PM
how to load a pdf on ipad
how to load pdf files on ipad
how to load pdf files to ipad
how to load pdf into ipad
how to load pdf on ipad
how to load pdf onto ipad
how to load pdf to ipad
how to load pdfs on ipad
ipad load pdf
load pdf into ipad
load pdf ipad
load pdf on ipad
load pdf onto ipad
load pdf to ipad
load pdfs on ipad
loading pdf files on ipad
loading pdf on ipad
loading pdf to ipad
loading pdfs on ipad
loading pdfs to ipad
