Wallpaper Problem - Won't Change
This is a discussion on Wallpaper Problem - Won't Change within the iPad Help forums, part of the Apple iPad Discussions category; My teenage son was playing with my new iPad the other day. He changed my lock screen and home screen to monster trucks. They displayed ...
Results 1 to 10 of 16
    6759
    Jun 2010
    Atlanta
    7
    My teenage son was playing with my new iPad the other day. He changed my lock screen and home screen to monster trucks. They displayed well for about a day and then all of a sudden the wallpaper grew 4x (I can only see the upper left quadrant of the image). After a bunch of fiddling with wallpaper settings I finally got the lock screen changed to a normal image and haven't messed with that since.
    My problem now is the home screen image is still 4x and I can't change it to anything. In settings/wallpaper, when I change the image, it fills the miniature home screen with the image I selected, but when I exit out, the same old 4x image is still there. I have also tried re-springing and re-booting the iPad several times. No luck. Any suggestions (other than complete wipeout and start over). I've just finished getting all my apps sorted and downloaded just the way I like it. It's just this wallpaper thing.
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    Just to make sure you are doing the right thing...
    Go into photos...choose the photo you want to make the wallpaper and click it...it should fill up the screen. In the upper right corner should be a little box with an arrow right under the battery indicator. Click it. Hit use as wallpaper. And then hit both lock screen and home screen.
    6759
    Jun 2010
    Atlanta
    7
    Tried that too. No luck. Anything else?
    I'm thinking I may have to delete the photo manually using sh, but I don't know where the iPad stores it.
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    Are you near an apple store? Either this is a really simple problem you are overlooking or your iPad could be messed up. Have you tried a hard reboot yet?
    6759
    Jun 2010
    Atlanta
    7
    I'd like to avoid a hard reset because I just got it set up how I want it and don't want to take hours & hours redoing it all.
    Now, I did try the last suggestion about an hour ago. I went into photos and set a photo as wallpaper for both the lock screen and home screen. Both screens took the photo, but while the lock screen looked fine, the home screen enlarged the photo 4x and only the upper left quadrant shows.
    I was able to change the lock screen back to the other photo, but can't change the home screen photo by itself and a can't get any photo to show full size on the home screen.
    Any more suggestions?
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    A hard reset doesn't kill any information it just reboots the device.
    6759
    Jun 2010
    Atlanta
    7
    If your talking about holding the power and home buttons together for 10 seconds, yes, I have done that at least ten times.
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    I'm not sure what else to tell you if you don't want to try a reset....
    6759
    Jun 2010
    Atlanta
    7
    By reset, do you mean a clean wipe?
    Please explain the procedure you want me to perform.
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    Yeah you already did a reset so I meant a clean wipe. You don't want to do that...so not sure what else to do other than take it in to an Apple Store.
  1. Best Wallpaper Site I've Seen So Far....
    By LMControl in forum iPad Wallpapers
    Last Post: 04-06-2011, 02:12 AM
  2. app to change wallpaper automatically
    By mrdinh in forum iPad Wallpapers
    Last Post: 12-15-2010, 09:50 AM
  3. Ferrari 430 Wallpaper Sample
    By Sonny Burnett in forum iPad Wallpapers
    Last Post: 05-05-2010, 09:56 PM
  4. Wallpaper orientation
    By abramsky in forum iPad Wallpapers
    Last Post: 03-29-2010, 05:10 PM
  5. iPad wallpaper, does it really rotate?
    By neither in forum iPad Wallpapers
    Last Post: 03-13-2010, 09:11 AM
can't change ipad wallpaper
can't change wallpaper on ipad
cannot change wallpaper on ipad
how do i delete wallpaper from my ipad
how do i get rid of image under wallpaper on my ipad
how to get rid of wallpaper on ipad
how to remove wallpaper from ipad
ipad wallpaper can't change
ipad wallpaper won't change
ipad wallpaper wont change
ipad won't show wallpaper
wallpaper wont change on my ipad 4
Tags for this Thread
