Since up grading my battery life seems shorter. Has anyone else noticed this. If so is there anything you can do
About it. Jeff
This is a discussion on Does version five affect battery life on the ipad within the iPad Help forums, part of the Apple iPad Discussions category; Since up grading my battery life seems shorter. Has anyone else noticed this. If so is there anything you can do About it. Jeff...
About it. Jeff
I to have shorter battery life after IOS5 not a big amount but I can tell its off .
from USA bucks county pa Sent from my iPad using iPF
