Need help connecting to a wireless printer
This is a discussion on Need help connecting to a wireless printer within the iPad Help forums, part of the Apple iPad Discussions category; Hi all! I just got a Canon MP495 wireless printer and hooked it up through my laptop, but now my Ipad will not detect it. ...
Results 1 to 10 of 15
    114765
    Oct 2011
    Colorado!
    9
    Hi all! I just got a Canon MP495 wireless printer and hooked it up through my laptop, but now my Ipad will not detect it. I looked around and saw I might need to buy the 'Print N Share' app for $8.99 to make it work. I also saw the Ipad might not be in sync with all printers out there. Do I need to buy another app just to print and if I do, how do I know for sure it will work?
    Can anybody help me along in this?
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Hello Badkelly - welcome to the forum!
    You have a number of options printing from the iPad (assume that you have an iPad 2 and possibly updated to iOS 5 - if not please clarify?): 1) use AirPrint - Apple's Wi-Fi option for compatible printers (not sure if yours is included - please read the manual - likely your easiest choice); 2) use a third party program such as you suggest in your OP; unfortunately Print N Share does not seem to be supported in iOS 5 if that is the version on your iPad.
    My solution using an older Canon Pixma MP printer is a program called FingerPrint (CHECK HERE) - requires putting the program on your iPad & also a 'free' little program on your computer (visit their website for an explanation); I used this app when my iPad was running iOS 4.x and after upgrading to iOS 5, the program still works fine. So, if you new printer does not offer Air Print, then give FingerPrint a try - good luck & please post back your experience!
    13990
    2 times
    Sep 2010
    Montgomery, NY
    187
    I just looked at the printer on Canon's site and it does not appear to be AirPrint enabled. I don't use printn'share so I can't comment on that, however there is a program out there called fingerprint (not an app) that will run on a Mac or PC that will allow you to print to any printers on your network. I am using it on my home system to access three printers and it works great. It is not free ($10) but you can D/L the free 30 day trial and try it out on your system before you buy.
    Tom
    iPad3-64GB 4G/WiFi Evasi0n JB and Mini-16GB WiFi No JB
    Pass the Kool-Aid
    114765
    Oct 2011
    Colorado!
    9
    i have version 4.3.5; is that the latest? i just got the ipad a couple of months ago and the printer just yesterday. i don't mind ponying up for an app that will allow me to print from the ipad, just want to make sure it will work before i do so
    13990
    2 times
    Sep 2010
    Montgomery, NY
    187
    Looks like Giradman is a faster typer than me. IOS 5 is the latest version and fingerprint works with your version and the latest one.
    Tom
    Pass the Kool-Aid
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by badkelly View Post
    Hello again Badkelly - appears that several of us were posting to your OP at the same time; first, if your Canon printer is not compatible w/ AirPrint, as suggested, then you'll have to explore my second suggestion, i.e. AirPrint or another compatible app.
    However, I would suggest that you upgrade to iOS 5 on your iPad - will be an eventual must - and as I already stated, my iPad after this upgrade has worked fine w/ AirPrint on my printer - so good luck in these considerations, and again please post back since others may find the information useful -
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by b00bie View Post
    Hey B00bie - are we in the Olympics?
    114765
    Oct 2011
    Colorado!
    9
    okay, it looks like the newest version for my ipad came available to me around the middle of october, so i'm hooked up to itunes and updating now. i may have to continue tomorrow as i'm leaving for work here in a little while, but thanks for all the information! i'll post as i progress on this.
    114765
    Oct 2011
    Colorado!
    9
    okay, i am updated to version 5.0 on the ipad and went to the collobos software site to download the trial version of fingerprint and it said that safari could not download the file. i researched a little more and according to this post: FingerPrint to AirPrint to your computer you need to load it on your pc and have nothing on the ipad.....then you should be able to see it on the ipad itself? i'm at work currently and will try it tomorrow when i get home, but it looks like that the printers will simply show up as options and you can select the printer, number of pages, and so on.
    13990
    2 times
    Sep 2010
    Montgomery, NY
    187
    Yea thats right it just installs on the PC, once it's running when you select print your printer(s) will appear in the list and you just select which one you want, remember this is accessing the printer through your PC and not directly to the printer so your PC must be on in order for you to access it.
    Tom
    Pass the Kool-Aid
  1. Wireless print to a non Airprint wireless printer?
    By nedcronin in forum iPad Help
    Last Post: 07-31-2011, 02:41 PM
  2. Wireless printer
    By dchoffman100@yahoo.com in forum AirPrint
    Last Post: 06-02-2011, 05:16 AM
  3. Replies: 1
    Last Post: 05-25-2011, 11:31 PM
  4. HP wireless printer app for ipad 2
    By cynthia gokavi in forum iPad Help
    Last Post: 05-16-2011, 04:19 PM
  5. Wireless not connecting
    By Pharlap in forum iPad Help
    Last Post: 03-14-2011, 09:26 AM
can canon mp495 print from ipad 2
can ipad 2 print to canon mp495
can my canon mp495 connect to my ipad
canon 495 connect ipad
canon mp495 airprint
canon mp495 is not showing in ipad air
connect ipad to canon pixma mp495 wifi
mp495 airprint
